speaker replacement advice
Discussion in 'Audio & Video' started by GeauxTigers, Aug 23, 2011.
  1. Aug 23, 2011 at 3:39 PM
    GeauxTigers
    GeauxTigers [OP] //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    i recently put in a new head unit into my truck (avh-2300dvd) and i'm looking to replace the stock speakers since i'm not getting the mids and highs that i want. i'm trying to avoid having to buy an amp. i know the stock speakers are 6x9, but should i get a different size like 6.5's, what brand of speaker, and 2 or 3 ways, replace just the front speakers or all four? here are the specs on the new head unit. TIA!!!:D
    General
    Chassis Size Code DD
    CEA-2006 Compliant Yes
    RMS Power Output 14 watts
    Peak Power Output 50 watts
    RMS Power Bandwidth 20-20kHz
    Preamp Outputs 4-channel
    Preamp Voltage 2 volts
    Subwoofer Preamp Outputs No
    Monitor Size (diagonal) 5 13/16
    Key Button Color Variable
    EQ Bands 5
    Wireless Remote Yes
    Steering Wheel Control Compatible Yes
    Parts Warranty 1 Year
    Labor Warranty
  2. Aug 25, 2011 at 10:32 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    When not adding a subwoofer I typically will install a good set of 6x9 components or 6x9 2 way coaxials up front as 6.5's really won't produce enough low bass to fill out the bottom end needed to make most music sound "full". Everybody has different listening tastes so the best bet if possible is to go around and listen to them yourself otherwise you'll have to rely on reviews etc online. Also, if not adding an external amp I look for speakers that are very sensitive to get the "most" from the headunit amps limited power and in in any case I stay away from those 3,4,5,6 way "gadget" :eek: speakers preferring to stick with just a "good" mid/tweeter.
  3. Aug 25, 2011 at 10:42 AM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    I installed some Pioneer 6.5 Components and they are clean and LOUD! There's hardly any bass though, which is why I have a sub as well.
  4. Aug 28, 2011 at 6:51 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    since when do speakers even play bass? you should have them crossed well before sub bass even gets close to them, and round speakers ftw.
    if you want good mid bass, buy mid bass speakers.
  5. Aug 28, 2011 at 7:01 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    6X9 up front and the rear are 6.5 I would replace all 4.. Your going to need adapters tho. Check out Mr.Marv or uhhh taco tunes but the have gotten loads of bad reviews.
  6. Aug 28, 2011 at 7:50 PM
    GeauxTigers
    Caleb
    hey guys. thanks for all the replies! I'm still debating on exactly what i want to do. I'm considering all options though.
  7. Aug 28, 2011 at 9:34 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    I dont know about you, but ANY set of speakers I put in my doors I want to play into the sub-bass range. Heck, I usally crossover between 63 and 80hz, depending on the crossover section available on the processor or deck I am using. And, of course, you know that is sub bass. ;)
    Lots of speakers play sub bass. I have a pair of 2" full range drivers that will play sub bass. Not loudly, but they will play it. :eek:
    The reality is, unless you are running a sub, people expect door speakers to play down to the 50hz range. And many of them do, unless you have a crossover in place... But bass is a function of moving air, so like Marv said, a bigger cone will help if you dont have a subwoofer.
  8. Aug 28, 2011 at 9:36 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    sub'd. im in the same boat.
  9. Aug 31, 2011 at 9:11 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    alright then, enjoy your 50hz tones played through speakers powered off a deck lol totally badass
  10. Aug 31, 2011 at 11:33 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    focal 165vr3- front
    focal 165cvx rear
    jl 13-tw5 sub
    jl hd900/5 amp
    thats the setup i did in my wifes car it sounds fukin amazing!
  11. Aug 31, 2011 at 11:35 PM
    platinumb
    Patrick
    denver
    yes technically any speaker will play "sub" bass but smaller speakers arent designed to so it will never sound right.
  12. Sep 1, 2011 at 6:55 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I would recomment 6.5" speakers over 6x9s. First off you have a lot more to choose from and they are typically a better acoustical speaker. I would recommend a set of 6.5 components, jl tr series if you plan to not get an amp or c2(or c5) series if you plan to amp them. I'm impartial to JL, greta bang for your buck with excellent audio quality
  13. Sep 1, 2011 at 10:44 AM
    Mr Marv
    Marv
    I'd agree that you have more choices in "good" 6.5" component sets which I would normally suggest when adding a subwoofer however the OP did not mention adding a subwoofer which is why I prefaced my comments with "When not adding a subwoofer". In any case here is a good read concerning the myth of round speakers sounding better than oval speakers.
    http://www.diymobileaudio.com/forum...-speakers-cant-sound-good-round-speakers.html
  14. Sep 1, 2011 at 1:17 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    Understanding how speakers work with crossovers, and what frequencies they play when a crossover is used, will help you greatly.
    And who listens to tones? What are you talking about?
    Not the point of the post. And sounding right is relative. If a 2" driver can play subbass, but due to cone area and excursion, it is only able to play it up to 50db, you would never hear it. Push it higher, and you get distortion. I am guessing this is what you mean by "never sound right", and that is absolutely correct.
    I would venture that 99.99% of speakers in peoples doors are playing sub-bass. Factory speakers are, any set of speakers a person puts in a door are, even if they have crossovers in place. Most "decks" will have a crosssover setting (that most people ignore) with a HP of ~80-100hz for a car. Even with the 100hz setting, you are only 12db down (again, most decks will have a 12db/oct slope) at 50hz, so you are getting plenty of sub-bass from the mids.
    Its what helps blend systems. I am certainly not advocating small woofers, though many companies are offering 5" - 7" subs that are known to do very well. Moving air is king, so I dont know that I would go that direction for loud bass, but it is ignorant to say that door speakers dont play sub-bass.
    And again, I am agreeing with Marv. Bass is about moving air, and a 'by nine will have more cone area, giving you a boost in bass output.
  15. Sep 1, 2011 at 2:25 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Moral of the story is use a speaker that has the mechanical and thermal limits to accomplish what you want. If you want sub bass from a speaker make sure it has a decent amount of throw or is acoustically loaded.
  16. Sep 1, 2011 at 2:58 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    All summarize-y today, aren't we...:p
  17. Sep 2, 2011 at 8:42 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    well theres a difference between dont and shouldnt, personally I like my music clear, and not muddy with a side of distortion.
