Speaker Spacer Rings - 07 Access Cab
Discussion in 'Mr Marv' started by 07tacoark, Oct 1, 2009.
  1. Oct 1, 2009 at 4:56 PM
    07tacoark
    07tacoark [OP] Still alive & breathing!!
    Red
    Dallas, TX
    07 4x4 SR5
    Rock Sliders, Lift + even more shit done over 11 yrs
    hey Mr Marv...
    i was just wonderin if u made any spacer rings at all. i didnt see any other threads askin this at all, so i figured id give it a shot.
    apparently the front door speakers that i have are gonna have to have some spacer rings in order for it to even fit. the speakers i am wantin to put in the doors are memphis 6x9 PR 15-PR693 (3way coaxial)
    i havent even tried to put in my 5 1/2 Kickers in the access door yet, so i dont even know if i need some for them as well.
    i guess my other question would be if u do make spacer rings, what are the choices for thickness?
    thanks
  2. Oct 2, 2009 at 8:23 AM
    arkane
    arkane Active Member
    OC, SoCal
    PreRunner Off-Road
  3. Oct 2, 2009 at 9:54 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Authorized Hybrid Audio Technologies Dealer (www.hybrid-audio.com) ARC Audio amplifiers, subs, processors now available! Helix Processors now available! For you super high end guys Brax amplifiers will be available soon! (PICS HERE and new website coming soon with Subwoofers, Amplifiers, Wiring Kits)
    Thanks for posting that and please feel free to post it anywhere it may help since it may be a while yet before my new website is up! :)
    You will need them for the rear as well in order to install the new speakers properly. Also, I can make them any thickness you need and the thread above will give you information on what you'll need for your specific speakers. :)
  4. Oct 2, 2009 at 11:30 AM
    mas32259
    mas32259 Well-Known Member
    NEPA
    2010 SR5 TRD Sport
    TRD short throw shifter, Eibach 1.6" lift coils 5100's on all corners, Ipod interface, Painted engine cover, radiator cover, skid plate, speaker grills overhead console, and added carbon fiber and chrome interior trim (Too much cheap plastic) TRD cat back, LED 3rd brake light. 100 lbs of sound deadner. Infinity ref. 6 1/2 all around. OBX pedals and shifter. DTRL mod, Alt. turn signal mod, LED's in glove box and console, LED's under dash lip and back A/C vent,Weather Tech mats. Took off antenea for wind noise
    I finished the back speakers and now moving to the front. I have not pulled the skins off yet so I want to find out what I am up against. I read the front tweeters are not on a crossover. Are the tweeters split off of the woofer feed or are they fed directly from the head unit and on a seperate chanel. I am keeping the stock HU for now. Just wondering how the stock components are fed.
  5. Oct 2, 2009 at 11:43 AM
    Mr Marv
    Marv
    Toyota uses what I call a "quasi" active wiring scheme with a capacitor to protect the so called tweeter. When using the factory headunit I typically tap into the input side and if you search the audio forum someone posted a thread showing another way to do it. BTW, this is the way to do it if you plan on disconnecting the "tweeter". If you plan to use the tweeter (I personally wouldn't but it's up to you!) you can just plug into the original woofer connection.
  6. Oct 2, 2009 at 1:10 PM
    mas32259
    NEPA
    2010 SR5 TRD Sport
    I am installing component speakers and was wondering what the best way to wire them to the factory HU. You say the tweeters are in series? I am not able to see where the factory woofer and tweeter wires are joined in the harness. Can woofer and tweeter wires be joined parallel. Also the speakers are Infinity reference 6020cs and rated @ 2ohms. There are many who would shy away from these low impedence speakers, I read that because of many factors in small gauge wire and crossovers and so on have enough resistance to present a 4 ohm load. I wired them up to the crossover and they measured 3.2 ohms, with just short wires for testing. I tend to belive that as claimed a 2 ohm speaker can be a 4 ohm load. If it does take out the HU no big loss.
  7. Oct 2, 2009 at 1:48 PM
    Mr Marv
    Marv
    The wires are joined inside the harness and if you find that thread above it will show you how to "jump" them or tap into them. I have heard of many using those speakers on headunit power with no problems and since the crossover input measured 3.2 ohms my feeling is it will be fine (speaker ratings are "nominal" and change with frequency so the headunit will "see" a wide range of loads with music playing).
  8. Oct 2, 2009 at 3:37 PM
    arkane
    OC, SoCal
    PreRunner Off-Road
    mas32259, I think this thread will help you out Factory Tweeters?
    factory tweeter/woofer wiring diagram by Evil Monkey
