Speaker upgrade for a 2nd gen questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nickle76, Aug 2, 2019.
  1. Aug 2, 2019 at 7:24 AM
    Nickle76
    Nickle76 [OP] Member
    Nick
    15 Tacoma
    Bil
    So i just got a 2015 Tacoma pre runner and I absolutely love the truck minus the stock system that came with it. Ive looked around on this site and there is a lot of talk about replacing the head units and replacing the speakers but they seem to be a few years old. I was just wondering what everyone is currently running in their trucks to give them the best sound. I listen to everything from rock to old twang country so im looking for a balanced sound. Seems from what I read that the tweeters and stock speaker set is weak as hell. Any advice would be appreciated. Thanks!
  2. Aug 2, 2019 at 10:32 AM
    bigbull
    bigbull Member
    2015 Red, 4x4, TRD Sport with heated leather, 4" lift
    2015 Tacoma Double Cab, standard premium head unit here.
    I installed the Subaru tweeters you can get here https://www.amazon.com/gp/product/B00PV6F8I2/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
    The Focal 6x9 exact fits for the front here https://www.crutchfield.com/p_091IC690TY/Focal-IC-690TOY.html (THEY ARE MUCH RICHER AND DEEPER THAN 6.5", DON'T SWITCH OR SKIMP ON THESE) and they come with wiring. Super easy!
    The rear 6.5" Focal for the rear with a fit kit https://www.crutchfield.com/p_091RCX165/Focal-RCX-165.html
    Had all 4 door speakers installed in about an hour and 15 minutes. The tweeters took a little more time as the connectors work for the 3rd gen better so I had to do a little easy wiring there and they took about 20 minutes each front door.
    Do this and you will thank me later, I promise. The results will blow you away. The only thing that will frustrate you is the detuning the factory head unit does past the Volume 52 mark, it turns down power in the woofers while it allows power to increase to the tweeters. It is so clear and nice and full sounding that you can run it at 52 and talk over it but rock the doors off. You can safely run the factory head unit at 52 with Bass all the way up on this setup. Sounds amazing with digitally recorded music. Could use some added volume with older analog recorded music. This will make you want a powered sub to match it, which I am doing next!
    jayway and Tatts521 like this.
  3. Aug 2, 2019 at 10:40 AM
    bigbull
    bigbull Member
    BTW, you will laugh your ass off in sheer wonderment when you pull the stock speakers out and look at them in your hand. Hahahahaha! Truly amazed they made any sound at all.
  4. Aug 2, 2019 at 11:38 AM
    Nickle76
    Nick
    15 Tacoma
    Bil
    I pulled the door off already to see what i was working with and just stared in amazement that they would put what they call speakers in this truck. I have looked at the focals but damn they are pricey. Are you running an amp to any of the speakers? Also with the tweeter how did you end up splicing the wires?
  5. Aug 2, 2019 at 11:55 AM
    bigbull
    bigbull Member
    Yes, they are pricey, but the sound quality is next level and the clear and full sound was not even comparable to some JL Audio 6.5" I put in the front doors first because I owned them already. It was a huge upgrade with this combo and worth the money in my opinion. Factory amp only. Some extra spade with wires came from Crutchfield and the door speakers. So I used those to connect to the tweeters. The plug on tweeters has 4 male spades. 2 in and 2 out as the sound is passed to the door speakers after the tweeters. So I went two to 1 spliced. In other words I cut and stripped both ends of the tweeter positive and negative lines, put both bare ends into the coupler and soldered. Then took the other side and soldered in the spade connector male and female because I live in the sticks and it was a Sunday so a 2 into 1 was not a wire connector I had laying around. The female spades push onto the suby speaker males, just be careful. Also, I used wire glue or something like this works, because soldering in that plug was not going to work, too tight an area.
  6. Aug 2, 2019 at 12:24 PM
    CStafford
    CStafford Well-Known Member
    Cameron
    2006 Silver Tacoma TRD Access
    If you are looking at JUST upgrading the speakers/HU and not putting a 4ch amp in, IMO you'd be wasting money to buy something really expensive. The more expensive speakers don't really shine until you put some real power to them.
    I'm running 6.5" CT Sounds Strato speakers in all 4 spots, you just need an adapter for the front. Before I had a sub put in they sounded pretty good on their own, but I do have an amp on them, around 70w RMS to each speaker.
    Rear: https://www.ctsounds.com/products/strato-6-5-coax
    Front: https://www.ctsounds.com/collections/component-speakers/products/6-5-component-speakers
    jayway likes this.
  7. Aug 2, 2019 at 12:33 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Are the Focal tweeters they include crap?
  8. Aug 2, 2019 at 12:37 PM
    bigbull
    bigbull Member
    I hear what you are staying and 90% of the time I'd agree. But this speaker swap was the largest change I've ever made to a factory system by just changing the speakers. I've spent almost $80,000 on car stereo equipment and installs over the last 35 years. So I wouldn't screw around with something that's not worth it. Maybe someday I will amp the 6 speakers. But it's so good only the sub is required for me now.
  9. Aug 2, 2019 at 12:39 PM
    bigbull
    bigbull Member
    No, not at all. I did listen to it without the Suby tweets installed. Not near as nice as with them.
    ACEkraut[QUOTED] likes this.
  10. Aug 2, 2019 at 12:39 PM
    CStafford
    Cameron
    Yeah i'll say that after seeing the stock speakers, you KNOW that anything different you put in there is guaranteed to sound much better, and i'm sure high quality speakers sound better on low power than low-mid quality speakers sound on the same low power.
    bigbull[QUOTED] likes this.
  11. Aug 2, 2019 at 12:39 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I have pioneer 3 ways in the front and lows in the rear, with the stock tweeters un plugged it comes together real nice. pretty solid mids and highs and good bass when you want the boom boom
  12. Aug 2, 2019 at 12:43 PM
    ACEkraut
    Aaron
    Durham, Maine
    Audio upgrade is on my to do list, but then again, there is a lot of stuff on my to do list. I have a decent quality set of tweeters that I was going to throw in one day, until I took apart the door and exposed the wiring and determined I needed a bit more information to install them. Sounds like I might be able to order the speaker set from Crutchfield and then use the tweeters I have with their accessories to make it plug and play. I like that idea. :thumbsup:
  13. Aug 2, 2019 at 12:48 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I would upgrade the headunit first before the speakers. Noticed a huge difference to my OEM speakers.
    techbill, Larzzzz and blu92in99 like this.
  14. Aug 2, 2019 at 1:32 PM
    c808nner
    c808nner Well-Known Member
    Oahu
    1995 Tacoma 3.4 MT Extracab
    I just installed rockfords all around including tweeters and am pretty unimpressed. After pulling the paper they call speakers out and putting in some decent aftermarket ones I expected a huge difference but it honestly sound a really similar to the stock ones. I’m hoping it’ll sound better after I put an amp in.
  15. Aug 2, 2019 at 1:42 PM
    bigbull
    bigbull Member
    c808nner that is a bummer! Sorry man. I should of recorded the difference on mine. It was that impressively improved. I am sorry I didn't do that now, but family and friends who have spent time in the truck are thoroughly impressed with the difference.
  16. Aug 2, 2019 at 1:47 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    I kept the factory head unit but replaced all speakers. Went with Kicker 6x9 in front lower and Memphis 1 inch tweeters. I put Kicker 6.5 in the back and also installed a Kicker 4 channel 300 watt amp, no subs but still have plenty of bass and plenty of volume. The stock speakers are a joke!!!
  17. Aug 2, 2019 at 1:50 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Sony XAV5000 headunit
    JL C-2 component speakers front and rear
    JL 10TW3 subwoofer
    JL JX500 Mono amp
    JL JX 4 channel amp
    Noico sound deadener on back wall
    Mr. Marv custom sub box
    Sounds amazing and bass is insane, couldn’t be happier
  18. Aug 2, 2019 at 2:01 PM
    Ninja Steve
    Ninja Steve Well-Known Member
    Eric
    Boise, ID
    2014 4x4 6MT SR5
    SnugTop Hi-Liner
    Just installed a new HU and front speakers in my 2014 Access Cab. My original Entune with navigation kept resetting and essentially kicked the bucket, so I thought why not.
    I bought this Alpine unit: https://www.crutchfield.com/p_500ILXW650/Alpine-ILX-W650.html
    Then I got these Pioneer speakers on a great sale: https://www.crutchfield.com/p_130TSG690/Pioneer-TS-G690.html
    The sound is way better than what it was, and yes, you will be amazed the stock speakers put out sound at all. They look like something I made in elementary school.
    Best part about the Alpine HU is that with the wiring kits from Crutchfield, it retains your backup camera and most of the steering wheel controls. It's also literally plug and play if you have them do the wires for you.
    Bad part is that you have to wire the mic that comes with it to use hands free calling and Google. I can upload pictures of where I mounted it if you want, out of the way and no wires.
  19. Aug 2, 2019 at 2:02 PM
    Ninja Steve
    Eric
    Boise, ID
    2014 4x4 6MT SR5
    SnugTop Hi-Liner
    Oh, you can also buy the amp from Alpine that mounts to the back of this unit. Pretty awesome and will be a future upgrade for me to get even better audio.
  20. Aug 2, 2019 at 2:22 PM
    bprout
    bprout Well-Known Member
    Brian
    SoCal
    2014 SR5 4x4
    Runs off Hopes and Dreams
    did you use the pioneer speakers for both front and rear??
