Speaker upgrade for an 2006 Tacoma Access Cab with JBL Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZBCTaco, Jan 26, 2020.
  1. Jan 29, 2020 at 3:53 AM
    DG92071
    DG92071 Well-Known Member
    If a door has a 2 ohm mid and a 2 ohm tweeter the load is still at 2 ohms because of the crossover splitting the frequencies.
    The wiring for the mid doesn't actually go through the tweeter but it does go through the tweeters plug. After the tweeters plug they are wired together. Toyota kept the wires arrangement the same for a few years and later switched the orientation of the wires within the plug. Something along the lines of positive negative positive negative was switched to positive positive negative negative, I don't recall exactly the arrangement or the year they changed.
    JBL is the speaker manufacturer.
  2. Feb 10, 2020 at 7:46 AM
    PeteSmashh
    PeteSmashh Well-Known Member
    Can someone tell me how you can tell if you have JBL sound on a 2nd gen Tacoma?
  3. Feb 10, 2020 at 10:00 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Your head unit should have "JBL" printed on it somewhere. Your front door panels should also have a "JBL" logo where the speaker grill is.
  4. Mar 7, 2020 at 6:42 PM
    jburner
    jburner Well-Known Member
    2013 Tacoma TRD DCSB Black
    How did these turn out? How odd you end up wiring the tweeter in with the 4 wires going into the tweeter with the OEM harness and only 2 wires on the tweeter?
