Speaker upgrade nightmare
Discussion in 'Audio & Video' started by Rottencotton, Oct 24, 2019.
  1. Oct 24, 2019 at 11:11 AM
    Rottencotton
    Rottencotton [OP] Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Did the tweeters and they were easy peazy. Then ordered MTX door speakers from Crutchfield. Pulled the front drivers door skin off and went to mount the speaker to it's bracket. Holes didn't line up. Tech support told me to use a Dremel tool and elongate the holes. Did so but they were too far off, finally gave up in disgust. In addition to that, the mounting clips were MIA and the instructions were useless. Crutchfield is sending me a set of Pioneer speakers to replace the MTX's.
    I went ahead and installed the back speakers and the brackets didn't quite line up with the holes in the truck. But they were close enough that elongating the holes did the trick. :angrygirl:
    PS: When I removed the factory speakers i went WTF? You can't even buy speakers this cheap and yet Toyota uses them in their vehicles. They should be ashamed.
    I have a feeling the next step will be adding an amp or replacing the head unit. The new speakers are not as loud as the OEM. Which way should I go? New HU or amp?
  2. Oct 24, 2019 at 11:18 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    Rottencotton[OP] likes this.
  3. Oct 24, 2019 at 11:40 AM
    Rottencotton
    Stinkin Rincon
    Thanks. I don't have the means to make my own brackets but I have a friend who's into woodworking big time. If I run into any more problems I'll hit him up for a favor.
    Minimag95 likes this.
  4. Oct 24, 2019 at 9:11 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    If I hadn't purchased a truck with the jbl system I would have bought a 4 channel amp and speakers while keeping the head unit factory.
  5. Oct 25, 2019 at 3:51 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Your new speakers aren't as loud because they're less efficient. The factory jobbers are very efficient and meant to be used with low power.
    I'd agree with a post above - make your own adapters. I use cutting boards for mine - they're impervious to water. Just don't use MDF - poor material for areas that are susceptible to water ingress.
    Takes a little time with a jigsaw, but cutting boards are a perfect material for this application
    Key-Rei and Rottencotton[OP] like this.
  6. Oct 25, 2019 at 4:26 AM
    Minimag95
    Niles
    Annapolis, MD
    Cutting boards are a good idea. And good point about the MDF and water, but MDF is fine as long as you coat them to prevent them from getting water-logged. Forgot to mention that in my post. I have birch adapters for my 6.5's and MDF for the tweeters and coated both with multiple coats of polyurethane. I have had luck doing it this way in the past.
  7. Oct 28, 2019 at 8:37 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    x2 on not using MDF... I just pulled my door cards to replace a blown tweeter and saw where my MDF adapter got wet and then expanded like a MF! Thinking about tracing them onto some cutting boards also.
  8. Oct 28, 2019 at 8:38 AM
    Zac of all trades
    Zac
    fwpfab.com
    It really depends on the speakers you have weather you should get a new HU or an AMP. If the speakers RMS is less than 50w then i would say you are fine with a new HU, if they more than 50w RMS then you will probably want an amp to power them.
  9. Oct 28, 2019 at 8:52 AM
    Rottencotton
    Stinkin Rincon
    Thanks for this. Speakers are 45 watts. Already have the rears installed. fronts will be here tomorrow. Will decide where to go next after I get them installed. Hopefully I'll be satisfied with the sound so i can spend my money on other goodies. I'm not picky when it comes to sound quality but the OEM speakers are pure shit, even the deaf can tell.
    Zac of all trades likes this.
  10. Oct 28, 2019 at 9:13 AM
    Zac of all trades
    Zac
    fwpfab.com
    Yeah you should be good then. Most aftermarket HU push about 45w RMS to each channel.
  11. Oct 28, 2019 at 4:40 PM
    rob feature
    rob feature Tacos!
    Colorado
    I'd say that's the exception. Most are giving about 17 or so tops. Most claim 50 or so, but don't actually make anywhere near that.
  12. Oct 28, 2019 at 8:21 PM
    Hooper89
    I think he has the stock head unit. He needs an amp. It'll cost about 100 for an adequate amp and another 100-150 to install and wire it.
  13. Oct 29, 2019 at 5:07 AM
    Zac of all trades
    Zac
    fwpfab.com
    Not to mention the better sound and signal a new HU will produce.... And yeah you are right, there are a lot of HU out there that lie!!!!!
  14. Oct 29, 2019 at 5:08 AM
    Rottencotton
    Stinkin Rincon
    I suspect you are correct. I'll know for sure when I get the fronts installed. Been raining last couple of days. Have to wait for it to clear before I can proceed.
  15. Oct 29, 2019 at 12:45 PM
    rob feature
    rob feature Tacos!
    Colorado
    Ya it has been demonstrated on this site somewhere that the frequency response of the factory head units is a function of volume and is not linear.
  16. Oct 29, 2019 at 1:01 PM
    Rottencotton
    Stinkin Rincon
    Does anyone know why the OEM Bluetooth mic can't be interfaced with an aftermarket HU ? I know there's a thread here about it but it turned out to be dead end and no explanation given as to what the problem is.
  17. Oct 30, 2019 at 6:37 AM
    Zac of all trades
    Zac
    fwpfab.com
    I just installed a after marker HU in my truck after about 2.5 years of running the stock HU on a DSP... sound is WAY different! Some songs do not have the same amount of bass, some have more! I need to re tune everything now.
  18. Oct 30, 2019 at 6:38 AM
    Zac of all trades
    Zac
    fwpfab.com
    That is one of the biggest reasons i never went with an aftermarket HU, but then i came across a really good deal and decided to jump on it, really miss being able to talk without holding my phone... but i also have air pods and they work great... when i have them with me.
  19. Oct 30, 2019 at 7:23 AM
    Rottencotton
    Stinkin Rincon
    I gotta have hands free phone. I'll go to jail without it.
    rob feature likes this.
  20. Oct 30, 2019 at 12:42 PM
    Hooper89
    Overall think you should just stick with the factory head unit. An amp and new speakers will be a huge improvement.
