Speaker upgrade opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jburner, Mar 7, 2020.
  1. Mar 9, 2020 at 9:13 PM
    DG92071
    DG92071 Well-Known Member
    Peak
  2. Mar 9, 2020 at 10:39 PM
    Waasheem
    Waasheem
    2007 xrunner
    I did upgrade to Panasonic avh-1500nex. Along with a dash kit, steer wheel control module, bu camera. It claims 50w x 4, claims being the key word.
  3. Mar 10, 2020 at 4:22 AM
    DG92071
    Your head unit is a Pioneer and not a Panasonic. Pioneer is the only company that uses MOSFET outputs and yes it actually is 50 watts X 4. Pioneer is also the only head unit that can be bridged. Best head unit available IMO. All other head units use an IC chip for their outputs.
    jungleman likes this.
  4. Mar 10, 2020 at 5:30 AM
    jungleman
    jungleman There can be only one
    North California
    2005 Access Cab Indigo Blue
    Nice upgrade!
    How do you like the speakers?
    Almost went with the kickers.
    Going to try them next whenever I wreck these alpines.
    DG92071 likes this.
  5. Mar 10, 2020 at 7:01 AM
    DG92071
    Someday I'm going to install 2 6's where the 6x9's go (in an enclosure), a 4" mid where the tweeters currently are, and tweeters on the sail panels. That will be awesome... someday.
  6. Mar 10, 2020 at 7:08 AM
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    Anyone ever replaced the speakers in the rear up in the headliner? How the heck do you get those out without destroying your headliner? Is it even worth the effort.
  7. Mar 10, 2020 at 7:58 AM
    jungleman
    North California
    Mine came with rear door speakers but if it was me Id disconnect those and leave them where they are and add two 6 1/2s in the rear doors without even pulling the headliner.
  8. Mar 10, 2020 at 9:25 AM
    Tah-koh-mah
    Yea I have a 2012 access cab and so mine came with useless tiny speakers in the headliners, I think my $5 alarm clock radio from 1989 came with better speakers.
    DG92071 and jungleman[QUOTED] like this.
  9. Mar 10, 2020 at 9:46 AM
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    Reading the description of what you get it’s 3 speakers.. you will need two of these..
  10. Mar 10, 2020 at 9:48 AM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    may need to clarify this, but those are good speakers.. I’ve had kicker before no issues
  11. Mar 10, 2020 at 10:08 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @jburner before you mount the tweeters, get a couple paint stirrers and attach the tweeters to them. Move them around till you find the spot where they sound best to you.
    Taco 422, jburner[OP] and jungleman like this.
  12. Mar 10, 2020 at 10:17 PM
    jungleman
    North California
    Yep yep yep
    I disconnected the tweeters years ago.
    A couple 4's there and 2 10's in new rear door panels w/the 6 1/2's but keep the 6x9s up front, components, and two new amps is my dream rig.
    Someday
    DG92071[QUOTED] likes this.
  13. Mar 10, 2020 at 10:43 PM
    Waasheem
    Waasheem
    2007 xrunner
    This combination is really simple, and sounds fantastic, crystal clear, plenty loud, no distortion even turned up. I just dropped it off tonight to upgrade the rear speakers. Adding the backup camera is really nice, no more bonking the wall.
    In comparison, in my old supra, I spent around 3500 for alpine 2 amps, eq, head unit, bazooka tube, separates up front, 4 6x9s rear. It was louder, sounded a little better, and the bazooka was intense or overkill.
    Some reason, I keep wanting to call it panasonic, it is a pioneer avh-1500nex.
  14. Mar 10, 2020 at 10:54 PM
    Waasheem
    Waasheem
    2007 xrunner
    Back in the good ole days, my little knowledge made me stupid and dangerous. I took my cheap boom box apart, took the crappy speakers out, put in some better car stereo speakers. Then took my big back tv apart, connected wires to its speaker, to a light switch you would normally mount to the wall, to wires sticking out, to the boom box speakers. Seemed ok except everyone thought it was hilarious I had a wall light switch on the side of my tv. It sounded, um, yeah better. The switch turned the tv speaker off so I could listen only through the boom box. Then if I moved the boom box outside or somewhere and forgot to bring it back in, I could flip the switch to hear the tv again.
    DG92071 and jungleman like this.
  15. Mar 10, 2020 at 11:30 PM
    #35
    jungleman
    North California
    Nice to have a system youre happy with.
    The kickers sounded really good at volume. Havent heard them in a vehicle tho.
    Good review thanks
    DG92071 likes this.
  16. Mar 10, 2020 at 11:32 PM
    #36
    jungleman
    North California
    Now you need a sub ;)
  17. Mar 10, 2020 at 11:36 PM
    #37
    jungleman
    North California
    Ive had some frankenstein rigs haha
    For the longest time I had a 12v inverter powering an alpine head unit into 2 6x9s in boxes and a couple house speakers in the garage is one I can think of offhand.
    Id still be running that I guess if a roof leak in a storm hadnt made a direct hit on both.
    DG92071 likes this.
  18. Mar 11, 2020 at 5:24 AM
    #38
    jburner
    jburner [OP] Well-Known Member
    2013 Tacoma TRD DCSB Black
    Per Crutchfield
    14 watts RMS CTA-2006/50 peak x 4 channels
    DG92071[QUOTED] and jungleman like this.
  19. Mar 11, 2020 at 5:51 AM
    #39
    capecodtaco
    capecodtaco Active Member
    Tom
    2014 Spruce Mica SR5
    Stock
    I put the kickers in my double cab last night. Much improved sound and clarity. I do have a Sony head unit though. I picked my daughter up from her job and she complained she could hear my music inside the building.
    DG92071, jungleman and Larzzzz like this.
  20. Mar 11, 2020 at 5:58 AM
    #40
    jungleman
    North California
    Which series kicker did you go with.
    And kids these days, no taste in music lol
