Speaker Upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nexusix, Mar 23, 2018.
  1. Mar 28, 2018 at 7:50 PM
    #61
    silvertxtaco
    silvertxtaco Well-Known Member
    2018 trd or
    mbrp ditch light brackets
    it really does after I listened to it for a while. my door speakers and deadening will be here friday...i knew they called it good Friday for a reason!
  2. Mar 28, 2018 at 7:56 PM
    #62
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    Ohhhh gotcha my mistake
  3. Mar 28, 2018 at 9:55 PM
    #63
    spiros1
    spiros1 Well-Known Member
    tung
    2017 trd sport double cap inferno
    pro grill, moonroof, plastidip flares
    Just upgraded with subara tweeters and just wow, thinking might go for the doors speakers as well.
    silvertxtaco likes this.
  4. Mar 29, 2018 at 6:52 AM
    #64
    CMillTacoma
    CMillTacoma Well-Known Member
    Craig
    Colorado
    2025 TRD OR Hybrid
    I did the Tweeters last night and yes much brighter sound coming from the highs now. Will do the rear doors tonight!
  5. Mar 29, 2018 at 7:25 AM
    #65
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Will look into this. Anyone with the DIY guides for install on the door speakers?
  6. Mar 29, 2018 at 8:24 AM
    #66
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It's well worth doing, I also put some sound deadening stuff in the doors, Crutchfield gives little instruction sheets.
  7. Mar 29, 2018 at 8:39 AM
    #67
    ZYBORG
    TX / S. FL
    3G TRD OR
    Nice, thanks!
    shakerhood likes this.
  8. Mar 29, 2018 at 8:40 AM
    #68
    ZYBORG
    TX / S. FL
    3G TRD OR
    :thumbsup:
    shakerhood[QUOTED] likes this.
  9. Mar 30, 2018 at 11:57 AM
    #69
    Draftpick
    Draftpick Member
    2019 SR5 DCSB 4x4
    guys there is new code only thru the ebay app and good for a few hours 15% any seller got the tweeters for $78.54
    code: PGETTHEAPP
    not seller restricted
    short time to use. exp. 11am PST / 2PM EST - 3/30
    #69
  10. Mar 30, 2018 at 2:51 PM
    #70
    finbar
    finbar Well-Known Member
    Michigan
    2017 TRD Sport
    I performed the Subaru speaker change out today. I notice the difference most when driving. Normally 40 is the driving around volume. 30 is the new 40. Bummed I missed out on the eBay coupons, but the install tool less than 30 minutes. As others warn, be careful not to drop tools or screws down into the dash. Also, use plastic panel removing tools so as not to scratch or mar the dash or A pillar.
    #70
  11. Apr 1, 2018 at 12:06 PM
    #71
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Does the sound deadening make the truck noticeably quieter? Or just the sound better? Did you do all 4 or just the front doors? I had to cancel my order on my truck with JBL because I did an extended drive in a sunroof truck and decided it would drive me crazy to have my head hitting the ceiling over every single bump.
  12. Apr 1, 2018 at 12:17 PM
    #72
    curtissp
    curtissp Well-Known Member
    #72
  13. Apr 1, 2018 at 12:42 PM
    #73
    shakerhood
    Southern Ohio
    I did not go crazy on the sound deadener, just 1 sheet per door. It did get rid of the tin sound and a little road noise, planning on pulling out the rear seat and doing the back of the cab when it warms up.
  14. Apr 4, 2018 at 9:01 AM
    #74
    doyledoonz
    doyledoonz Active Member
    Kyle
    Ogden, Utah
    2017 Tacoma TRDOR DCSB
    I'll also add that @Mr Marv is great to work with! He went out of his way to answer questions and help me find the perfect solution for my listening.
    CoastieRon likes this.
  15. Apr 4, 2018 at 9:47 AM
    #75
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Darn those Focal's... going to have to do it one of these days. Very happy with the set of components I put into my S2000 years ago.
  16. Apr 4, 2018 at 1:19 PM
    #76
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Focal? Here is the route that I went.
  17. Apr 4, 2018 at 1:45 PM
    #77
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    I paid for the JBL upgrade in my TRDOR but not impressed at all...
    Don't want to change the head unit but would like better speakers all around. Anyone know what would work ...?
  18. Apr 4, 2018 at 1:48 PM
    #78
    toyotatacomaTRD
    According to the guy I spoke to at an audio shop, if you're into upgrading the sound, it's way easier with non-jbl. Someone will hopefully be able give you a better answer, but it sounds like the JBL isn't easy to change.
  19. Apr 4, 2018 at 1:50 PM
    #79
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Call Crutchfield and ask for Lee. He will tell you all available options. Have worked with him for 20 years on many vehicles.
  20. Apr 4, 2018 at 2:00 PM
    #80
    fxrman
    palm springs
    Was hoping for a speaker upgrade not the the whole unit.
    Sounds like Toyota screwed me.
    I mean you pay for the upgrade and what you get is substandard crap with the JBL name on it.
