speaker wire
Discussion in 'Audio & Video' started by pinktaco808, Apr 23, 2011.
  1. Apr 23, 2011 at 7:27 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    what do you guys suggest i run for the speaker wire from my amp to my front component speakers??? best sounding
  2. Apr 23, 2011 at 8:42 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Ofc. Just go buy some.
  3. Apr 24, 2011 at 8:48 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
  4. Apr 24, 2011 at 9:02 AM
    The Big O
    The Big O Well-Known Member
    James
    Lyndhurst, New Jersey
    '11 Taco 4x4 SR5 - Black
  5. Apr 24, 2011 at 12:04 PM
    pinktaco808
    thanks everyone
  6. Apr 24, 2011 at 4:39 PM
    DevL
    DevL Well-Known Member
    Just some 16ga of anything... none of it sounds better. I spent money on pretty wire and you cant even see any of it lol. Twisted, shielded, etc. all that is crap for speaker wire and does nothing... if it is copper its good enough... 16ga is all you need to concern yourself with and 12ga for subs. Litterally thats all there is to know about spekaer cable. You can buy the cheapest shit in the world and it will be just as good as $300 wire as far as sound quality.
  7. Apr 24, 2011 at 4:44 PM
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    This^^^ just make sure its stranded and you'll be good cus solid is harder to feed
  8. Apr 24, 2011 at 5:43 PM
    DevL
    Yep, higher strand counts are more flexible but does not do anything for sound. Same goes for am power and ground cable... likely you will use 4ga... in some instances larger but usually 4ga is adequate for a single cab. You could use extension cord cut up and it would sound the same.
  9. Apr 24, 2011 at 8:13 PM
    pinktaco808
    -as long as copper
    -16 ga
    that the only 2 main thing right???
  10. Apr 24, 2011 at 8:20 PM
    Bamfs01
    Bamfs01 Well-Known Member
    Magnetic Gray TRD Offroad. Locker, ATrac, DAC
    Stock leaf pack with TSB AAL, Wheelers progressive 3 leaf AAL, and Bilstein 5100's in the rear. Front OME coilovers with 885 coils. Cab mount chop. http://www.tacomaworld.com/forum/wheels-tires/37734-how-tire-rub-cab-mount-mod.html rcbs204 4x4 Illuminated Switch. http://www.tacomaworld.com/forum/lighting/68173-rcbs204-4x4-illuminated-switch.html JBL P963 6x9's and an MTX 10" sub wired inline to the stock HU with a MTX Jackhammer 404 amp. Rear diff breather relocation mod.
    Lol I'm doing this and have been for years. It's not actual extension cord but the stuff that's used for lamps, which is the same thing depending on the extension cord. Got a spool of it for cheap. Works fine
  11. Apr 24, 2011 at 10:32 PM
    pinktaco808
  12. Apr 24, 2011 at 10:33 PM
    pinktaco808
    how you know if it pure copper if it doesnt say anyrhing on it or because you found some wire laying around
  13. Apr 25, 2011 at 8:11 AM
    DevL
    Oxygen free copper has no impurities of iron and slightly better resistance but not enough to matter. Tinned copper make soldering easier but again is not necessary.
    The guy above is saying he uses lamp cord for wire. You could even use aluminum but it would have to be thicker. Don't overthink or over research this topic any 16ga copper is adequate.
