speakers are harder to install than i thought.
Discussion in 'Audio & Video' started by Rucas, Dec 27, 2009.
  1. Dec 27, 2009 at 4:39 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    haha, well the speakers themselves werent that bad, the major hold up was disconnecting the freaking plugs! That alone took a lot of time and frustration but I got all of the doors except the driver side door unpluged.
    A little advice for others...
    When you get the door panel off and only connected by te wires, try rotating the pannel so the plugs are facing upward. That technique helped a lot.
  2. Dec 28, 2009 at 10:47 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I have so much damn trouble removing harnesses. I did the DTRL mod and had to remove a bunch of plugs from the fuse box inside the dash. That was such a bitch.
    Some you squeeze the top/bottom, others the sides, others you have to push in a tab, MAKE THEM ALL THE SAME!
  3. Dec 30, 2009 at 3:41 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    seriously.
    And use the buddy system, it made things easier.
  4. Dec 31, 2009 at 2:19 AM
    tntacoma
    tntacoma Well-Known Member
    tn
    technique that I found that works on the front and rear doors of a 2007 dc. before you remove the panels, take a small screw driver for flat pry tool, and very carefully remove the power window controls. Pry from the front up, it just snaps in. Disconect the harness and then remove the panel, way more simple.
  5. Dec 31, 2009 at 7:41 AM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Ya i was trying that on the front drivers door forever, but i gave up and just had someone hold the pannel in place while i did the work.
