Speakers crackling at high volume
Discussion in 'Audio & Video' started by tacoapw, Aug 27, 2011.
  1. Aug 27, 2011 at 5:26 PM
    tacoapw
    tacoapw [OP] Member
    Northeast
    2011 TRD Sport Access Cab
    35 Watt 6000K HID's, Westin Bull Bar, Westin Step Bars, PIAA 540 Driving Lights, Uniden PRO520XL CB
    Just got a 2011 tacoma access cab and noticed that the speakers crack and sound like crap at high volume. Wondered if anyone could tell me why, and how maybe to fix it?
    Thanks in advance
  2. Aug 27, 2011 at 5:35 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    Turn the volume down.
  3. Aug 27, 2011 at 5:36 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Does it do it on all audio sources or just one? Ie, ipod, radio, cd.
  4. Aug 27, 2011 at 5:40 PM
    brian
    Elizabeth City, NC
    I'm guessing his source might be clipping, I know my phone and A LOT of mobile devices do it. I have to turn my phone down two notches otherwise.
    Also, what is your bass set to? If you're cranking it up on a stock stereo, it should be close to 0
  5. Aug 27, 2011 at 5:40 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    honestly, the stock speakers are great for medium volume listening, but if you want true clear high volume performance you need to change them out and add a processor and an amp (if you are going to keep the stock h.u. if not just an amp).
  6. Aug 27, 2011 at 8:30 PM
    tacoapw
    tacoapw [OP] Member
    Northeast
    it does it on all audio sources
  7. Aug 27, 2011 at 8:34 PM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    YEAH i have the same problem with my 2011 tacoma chalk it up to shitty ass speakers from the factory hell I still crank my bass to 5 and my volume to max I'll fry those pieces of shat then I'm gonna build a glass shattering system!!!
  8. Aug 28, 2011 at 9:51 AM
    brian
    Elizabeth City, NC
    crackling shouldn't really be because of shitty speakers...unless you blew them, it probably the amp section of the head unit. Set all your audio settings to 0, bass treble, etc. Put it at 2/3'rds volume. It shouldn't crackle.
    Probably time for a new head unit. Unless you can attribute it to a single speaker. Also, do you have a base model stereo? Might be worth checking connections on the back side. If you have a JBL stereo, we can investigate that a little differently.
  9. Aug 28, 2011 at 10:49 AM
    tacoapw
    tacoapw [OP] Member
    Northeast
    When it happens all speaker values are set to 0, and none of the speakers are blown
  10. Aug 28, 2011 at 11:20 AM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    try fading it front and back, see if it occurs with all the speakers.
    I have maxed out the volume on my stock headunit, and have never had that problem. As a couple posters mentioned, once you are above 40 the bass does not go any higher, but the treble will still increase.
    If you are in the 30s on the volume knob and get this sound take it to
    the dealership.
