Speaking of catalytic converters
Discussion in 'New Members' started by nfrank, Oct 4, 2021.
  1. Oct 4, 2021 at 3:42 PM
    nfrank
    nfrank [OP] New Member
    2008 Toyoto Corolla
    Just read through a 2013 thread, "Catalytic Converter RIPOFF", and decided to join tacomaworld. I was just told today by a muffler shop that my cat had died and that I was looking at >$2K to replace it. High cost due to expense (~$1500) of the unit itself. I called around and did a bit of reading, all of which seemed to support these high costs ("palladium, platinum, etc worth much more than gold . . ."). Then I found a local auto parts chain that sold a cat for my 2008 Corolla for ~$200. Then I read the 2013 forum. I get one of the points made: you get what you pay for. But I have an added question. Is it ok to buy a cheapie cat for a vehicle that likely only has a limited lifetime left? (I've now put on only 75,000 kilometers in 14 years and figure it will make it to 100,000 kilometers/20 years). I mean instead of a $1,000 high end model?
  2. Oct 4, 2021 at 3:45 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Welcome to Corolla World!
    Black DOG Lila and Malvolio like this.
  3. Oct 4, 2021 at 3:49 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    A bit of interesting info I found was that the reason cats “fail” is that the element is tide gets clogged with carbon buildup and it no longer works as efficiently as it did when new. A few you tubers removed their cat and washed it and were able to clear CELs that way. Food for thought if you’re able to unbolt the cat and soak it overnight.
    I had previously used a fuel additive from Rislone specifically made to clean cats and it worked to clear an engine code on a previous car.
    Black DOG Lila likes this.
  4. Oct 4, 2021 at 3:56 PM
    nfrank
    2008 Toyoto Corolla
    Thanks GHOST. The muffler shop told me my cat died because of the salt they slather on our roads during the cold Canadian winters. But when I have my own mechanic eyeball my cat I'll ask him about what you're suggesting.
  5. Oct 4, 2021 at 4:00 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    It will depend on why your cat failed, and if your emissions label says meets california state emissions.
    It will also on if you have good or bad o2 sensors, in addition if you are leaking coolant internally you will quickly destroy any cat you install.
    No one here on the internet can give you a quick answer with out alot of data.
    Or I could work at some parts houses and say "yeah that'll fix er."
  6. Oct 4, 2021 at 4:31 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    buckhuntin-tacoma likes this.
  7. Oct 4, 2021 at 6:51 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  8. Oct 4, 2021 at 6:54 PM
    eon_blue
    Azusa, CA
    I don't know what smog testing is like in Canada or if you even have to do it, but many of the dirt cheap aftermarket cats do not meet emissions requirements (here in the States anyway). If the person doesn't live where smog tests are mandatory then it doesn't matter. But I certainly wouldn't expect a cheap cat to last as long as an OEM one
