Special Computer to Bleed ABS SYstem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jan 19, 2025.
  1. Jan 19, 2025 at 8:26 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    The Tacoma ABS brake system requires some sort of a special computer hooked up to the truck to properly bleed the ABS system.
    This was on another thread. Do you have to use a special computer to bleed ABS system only when replacing the brake master cylinder or when replacing what components?
    Ive changed calipers before and never bleed using this "special computer".
  2. Jan 19, 2025 at 8:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You typically only need to do an automated bleed on the ABS unit when the unit itself is replaced, it's typically not required when replacing calipers or the master cylinder (unless you have the hydraulic booster/ABS unit).
    Not really anything special, simply need a bi-directional scan tool that has that function.
  3. Jan 19, 2025 at 8:59 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Its THE best way to flush your brake system
  4. Jan 20, 2025 at 8:23 PM
    TacoBell07
    Four door 2wd Taco
    Planning on doing a Tundra master cylinder and brake booster upgrade on my truck. I know Tundra booster is dual diaphragm but not sure if it is hydraulic booster or not. Guy in another thread i posted did this and mentioned so just wanting make sure i dont need anything special or worry about getting air into ABS system. I thought the proportioning valve might stop air from getting into system past that point.
  5. Jan 20, 2025 at 8:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The hydraulic booster looks like this, in Tacoma's it's exclusive to 09+ TRD OffRoad/Pro models and pre-09 models with VSC which was an uncommon option.
  6. Jan 20, 2025 at 8:42 PM
    TacoBell07
    Four door 2wd Taco
    Yea i definitely don't have that. Mine is a 08 Prerunner. The OP for that thread it looks like definitively has a Taco newer than 09 to me.
