Special Service Tool - Crank Pulley Remover
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJPP, Jan 8, 2011.
  1. Jan 8, 2011 at 10:45 AM
    TacomaJPP
    TacomaJPP [OP] To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    NegroTundra asked me to post pics/print of my homemade Special Service Tool (SST) for removing the crank pulley.
    Here it is.
    EDIT: Please note, I screwed up on my print! Rotate the three bolt holes 90 degrees. Arghhhhh. See picture.
    I use the couple nuts to stick through the holes in the SST plate and thread onto the studs behind the crank pulley. The "tee" post lays against the frame rail and locks there as pressure is applied to the crank pulley nut. If I recall, it takes 217 ft-lbs to torque the crank pulley nut.
    Enjoy:
  2. Jan 8, 2011 at 11:10 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
  3. Jan 8, 2011 at 5:53 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Cool beans man....thanks a lot. Will print this out and start fabbing!
    Are the holes on the diagnal ends of the flat stock there for a reason? Or were they just there when you got the plate?
  4. Jan 8, 2011 at 5:59 PM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C
    How do you keep from bending the bolts? I made a tool out of bar stock and bent several grade 8.8 bolts.
  5. Jan 8, 2011 at 6:53 PM
    Miata Tech
    Miata Tech Well-Known Member
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    ChaseCam Video System, Optima YellowTop, ScanGauge II, Heated Drivers Seat, Sirius Satellite Radio, K&N Drop In, E-Locker Guard, Extang Black Max Tonneau , Streamlight Stinger, All Synthetic Fluids, USA-Spec iPhone Interface, Gentex Auto Dimming Compass/Temp Mirror
    Wouldn't be a bad idea to use a New crank bolt too.
  6. Jan 8, 2011 at 9:34 PM
    joeer77
    joeer77 Active Member
    North Plains OR
    Bilstein 5100s
    Can you rent a torque multiplier and "pulley locker" from Autozone? I bet they have at least one of these tools for rent. 210ft-lbs sounds awful high. Is that out of the FSM? I think my wrench only goes to 150ft-lbs darn it.
  7. Jan 8, 2011 at 10:09 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Did you catch my note above where the holes need to be rotated?
    Anyway, about the diagonals holes...they were already there.
  8. Jan 8, 2011 at 10:10 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    I used a 250 ft-lbs torque wrench (I'm guessing a 24" handle on it) and I had no problems breaking it loose. Of course I am a fine specimen of the male physique....
