Special_K's 4x4 Long Travel build
Discussion in '2nd Gen. Builds (2005-2015)' started by Special_K, Aug 28, 2010.
  1. Mar 8, 2012 at 8:15 PM
    #1701
    Special_K
    Special_K [OP] o_o
    Eddie
    Alexandria, VA
    2019 Tacoma Cav Blue
    i was saddened as well lol
  2. Mar 8, 2012 at 8:16 PM
    #1702
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    what video??? :spy:
  3. Mar 8, 2012 at 8:20 PM
    #1703
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Exactly...
    Eddie get it up on Vimeo, you're depriving of its awesomeness :cool:
  4. Mar 8, 2012 at 8:23 PM
    #1704
    Special_K
    Special_K [OP] o_o
    Eddie
    Alexandria, VA
    fine. it's not even good it was the first time out with full LT.
    the go pro, singlefin's awesome camera shots, and the song are the only reasons that video is worth watching haha. anyway, it's being uploaded now :)
  5. Mar 8, 2012 at 8:26 PM
    #1705
    theduck911
    Max
    Locked and Geared!
    Yeah its good,but the music makes it the video! Should definitely make a new one :cool::p
  6. Mar 8, 2012 at 8:28 PM
    #1706
    Special_K
    Special_K [OP] o_o
    Eddie
    Alexandria, VA
    When the rear set up is done and i stop messing with the suspension for a while and can dial it in, I plan on making a new one.
  7. Mar 8, 2012 at 8:38 PM
    #1707
    theduck911
    Max
    Locked and Geared!
    :popcorn:
  8. Mar 8, 2012 at 8:43 PM
    #1708
    Special_K
    Special_K [OP] o_o
    Eddie
    Alexandria, VA
    yeah no kidding. mas popcorn. this hobby blows
  9. Mar 8, 2012 at 9:10 PM
    #1709
    Special_K
    Special_K [OP] o_o
    Eddie
    Alexandria, VA
  10. Mar 9, 2012 at 6:56 AM
    #1710
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That video makes me miss off-roading. :(
  11. Mar 9, 2012 at 10:37 AM
    #1711
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  12. Mar 9, 2012 at 11:08 AM
    #1712
    jjbsocal
    jjbsocal Well-Known Member
    Jeff
    So☆Cal
    2010 DCLB PreRunner TRD Sport
    Camburg MT; 4.0 Spindles and UCA's, Fox Extended Travel with Resi's all 4 Corners, All Pro Expo Leaf Pack, Method Standard's, BFG AT's, DTLT's, 1st Gen TRD CAI, Magnaflow Pro Offroad Exhaust..
    That vid was just pure awesomeness..
  13. Mar 15, 2012 at 10:14 AM
    #1713
    theduck911
    Max
    Locked and Geared!
    Didn't want to spam the F/S with questions,
    Just interested to know more about the Built Right LT. General Specs? Details?
    Truck just gets more and more badass:cool:
  14. Mar 15, 2012 at 11:10 AM
    #1714
    rcfreak201
    rcfreak201 Well-Known Member
    x2 :popcorn:
  15. Mar 15, 2012 at 6:34 PM
    #1715
    Special_K
    Special_K [OP] o_o
    Eddie
    Alexandria, VA
    Getting the specs soon
  16. Mar 15, 2012 at 6:35 PM
    #1716
    Sabre
    Sabre Well-Known Member
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    I noticed a bump strike pad on lemboskis lca pic so that defintly a plus
  17. Mar 15, 2012 at 8:45 PM
    #1717
    rcfreak201
    coilover, bypass, and bumpstop? because i saw two tabs for the lower shock mounts
  18. Mar 15, 2012 at 9:50 PM
    #1718
    Special_K
    Special_K [OP] o_o
    Eddie
    Alexandria, VA
    A few specs on the Built Right Fabrication kit
    -100% bolt on
    -3.5in over stock uniball uppers and lowers
    -13.5in usable wheel travel with 4wd
    -Ability to run dual 2.5in shocks + strike plate for a hydro bump
    -TIG welded chromoly construction
    -Boxed lower, tubed upper
    -Approx. 20lb less unsprung weight than the TC kit
    This is lembowski's kit
  19. Mar 15, 2012 at 10:00 PM
    #1719
    Jerez
    Rod
    Ontario Ranch
    Estock
    I really wanna see the finish product on lembowskis n your truck :woot: sick!!
  20. Mar 15, 2012 at 10:37 PM
    #1720
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Holy Shit! I want!
