Specific 5100 setup question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by h22dx, Jan 17, 2013.
  1. Jan 17, 2013 at 5:32 PM
    h22dx
    h22dx [OP] Well-Known Member
    louisville,ky
    07 trd sport
    Ok so I have decided to just go with 5100 setup for my truck. I just want it to sit a bit higher,level, and put some meaty 32's on it. I know I can put 32's on now but just clearing the air of what I want. Heres my measurments:Front-34 1/8 from the ground and 20 1/4 from center of hub. Rear-35 1/2 and 21 3/8. So based on your guys expertise :D, what setting do i need the fronts at and what size aal in the rear? Also 5125's in the rear just allow you to flex more? Thanks a lot guys!
  2. Jan 17, 2013 at 5:34 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    It depends on how much you want it lifted. Run a 1.5"aal and set the billies at 2.5" if you want the max out of them
  3. Jan 17, 2013 at 5:51 PM
    h22dx
    louisville,ky
    07 trd sport
    I just dont want to risk the possibility of getting aftermarket uca's. So I guess if I set the fronts to the middle setting I would get a 1in aal?
  4. Jan 17, 2013 at 6:11 PM
    ntilehman
    Seth
    Charlotte, NC
    don't go over 2" in the front if you don't want want uca's. 1" aal should be good. depends on how much weight you carry if any.
  5. Jan 17, 2013 at 6:16 PM
    PRIMETIME
    PRIMETIME Well-Known Member
    Albuquerque
    06 DCSB SPORT 4x4
    I run my front at 2.5 we'll see if it'll align on monday. I will post results with stock uca's.
  6. Jan 17, 2013 at 6:20 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    billies set at 2.25 in the front don't require aftermarket upper control arms from my personal experience.
  7. Jan 17, 2013 at 6:29 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    Based on your Center hub to Fender difference and without a AAL...I would suggest only .85. and you will be able to fit 32" or 265/75 without rubbing
    I had a 2" difference front to rear, so I did 1.75" and it came out perfectly level. See my write ups
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/242974-bilstein-5100s-question-2.html#post5827593
    If you add 1.5 AAL, then set your front at 2.5" and you will only have .25 difference (which is what I have....so it will basically be level.)
    Good Luck
  8. Jan 17, 2013 at 6:31 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    you can fit 267/75r16 on stock wheels without any lift and not rub.
  9. Jan 17, 2013 at 7:08 PM
    h22dx
    louisville,ky
    07 trd sport
    How does yours ride at 2.5?
  10. Jan 18, 2013 at 4:07 AM
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    I said mine is set at 1.75 and is perfectly level, it rides awesome...much better than stock.
    I said my(front to back) difference was at .25 which is the same if you did yours at 2.5. Make sense now?
    Homer - on my 2012, my 265/75/16 did rub when turned all the way and you went over a small bump(even with the mud flaps removed), like turning into the driveway (although my wheels are 8.5 wide, so that might have something to do with it). Anyway after 1.75" lift, no rub at all.
  11. Jan 20, 2013 at 5:01 PM
    h22dx
    louisville,ky
    07 trd sport
    Gotcha. Do you have any pics of your truck with the lift on with your stock wheels?
  12. Jan 20, 2013 at 7:02 PM
    PRIMETIME
    Albuquerque
    06 DCSB SPORT 4x4
    I have one
  13. Jan 21, 2013 at 4:55 PM
    h22dx
    louisville,ky
    07 trd sport
    could you post it please?
  14. Jan 21, 2013 at 6:45 PM
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    I can't add much here since I have a regular cab, but my Bilsteins @ 2.5" and Wheeler's rear 3 leaf progressive AAL + overload kept, resulted in an almost level truck (front may be tiniest bit higher). Hell, it might be level, but I do have a camper shell on. I'm not sure how much that contributes to the sag, but I can only assume if this identical setup was used in 6 cyl, you'd be either a) perfectly level, or b) have the slightest amount of rake.
    I guess the TSB could affect things, I just had the stock 3 leaf total setup with no TSB applicable. I may have gone with a 2" AAL if I could go back in time not necessarily for the rake, but just to ensure that I have 0% bro lean going on. Aligned today, came out fine to my great liking.
  15. Jan 21, 2013 at 8:12 PM
    PRIMETIME
    Albuquerque
    06 DCSB SPORT 4x4
    stock
    lifted
  16. Jan 22, 2013 at 12:02 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I have a 2011 DCSB TRD off road Prerunner. If I set the 5100s to .85 how much would it lift my truck? Would it leval the truck? I do'nt wont to do anything in the rear. I would do just the 5100s in the rear.
  17. Jan 22, 2013 at 2:52 PM
    h22dx
    louisville,ky
    07 trd sport
    So what is your setup besides 2.5? Stock coils, three or 4 pack leaves, size of aal? That looks great by the way
