specific gearing question (urgent)
Discussion in '1st Gen. Tacomas (1995-2004)' started by motostar00, Jun 18, 2013.
  1. Jun 18, 2013 at 8:58 PM
    motostar00
    motostar00 [OP] Grind it till ya find it
    N.C
    1998 v6
    tinted windows, 3 inch bilstein/eibach lift , HIDs, smoked out lights, Jensen flip out radio, 17inch fuel mavericks and 33s
    so i am regearing from 3.90 to 4.56 front and back. i bought them from a friend who had them in his tacoma. same motor and axles. i bought the ring gears, pinion, and third member. the shims and pinion were not removed or touched. all i did was replace his carriers with the ones from my third members. the carriers are the same but his spider gears were welded and i did not want that so i changed it with my carriers (which are the same). my question is if i need to set my gears and back lashthem? i didnt think i did since it was already set up for the same model tacoma and axle. plus the carriers are i dentical.. im a little new to gearing and such. any help would be appreciated!
  2. Jun 19, 2013 at 7:16 PM
    motostar00
    N.C
    1998 v6
    nevermind i figured it out with my friend.
  3. Jun 19, 2013 at 8:24 PM
    Seventh
    Seventh Insert witty title here
    Boston, MA
    2001 Reg Cab 4x4
    You should post the solution/answer, in case someone else finds this in a search.
