Specific questions regarding replacement leaf springs
Discussion in 'Suspension' started by MicahTheProphet, May 20, 2010.
  1. May 20, 2010 at 10:16 AM
    MicahTheProphet
    MicahTheProphet [OP] New Member
    Indiana
    00 Tacoma
    I searched the forums but was unable to find the answers to my questions.
    Last week I broke a leaf spring on my 2000 tacoma xtracab. It poped out and cut the brake line making for a very interesting ride home. I did a bit of research and decided on using the skyjacker softride 2.5" leaf packs. I will worry about lifting the front end latter on when I have the extra cash. I dont really care if it sits level for now.
    I have a few questions.
    1. Do I have to replace my rear shocks with the new leaf pack or can I leave the stock shocks on there for now?
    2. Will I need a longer brake line?
    3. Can I reuse the old u-bolts and shackles with the new leaf pack?
    Thanks for the help.
    Micah
  2. May 20, 2010 at 10:18 AM
    only_K
    only_K 1st Gen. Pride
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    K&N drop in filter, Magnaflow Exhaust, Billet grille. All 4 Bilstien 5100s. Fronts set at 2.5". Rear 2" AAL.
    You might need longer shocks, or shock extenders.
    I dont think you will need longer brakelines.
    It depends on how thick the new pack is.
  3. May 20, 2010 at 10:51 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If the new pack gives 2.5" of lift. You will need longer shocks and brake lines. That is really too much lift in the rear (unless you have a heavy canopy or lumber rack) even if you have a 2.5" lift in the front. You can get away with stock shocks, but you will probably feel them top out.
  4. May 20, 2010 at 2:20 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    you'll need new u bolts too
    longer than stock
  5. May 20, 2010 at 2:40 PM
    rick
    rick `
    x2 and welcome to TacomaWorld
  6. May 20, 2010 at 6:01 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    the ubolts need to be replaced with new ones for sure as for the shackles you could probably get away with reuseing them but being that your truck is 10 years old it certainly wouldnt hurt to put some new ones in,theyre not terribly expensive anyway.
  7. May 20, 2010 at 10:35 PM
    MicahTheProphet
    Indiana
    00 Tacoma
    Thanks for the replys everyone.
    I'm not sure what you mean by 2.5 being to much lift in the back. Can you elaborate?
    I'm going to add new ubolts and shackles to the list. Are there any recommended websites to purchase these from?
    What do you guys recommend for shocks? I see alot of people talking about the 5100's. What do I need to know? Any recommended sites?
    Thanks again. You guys rock.
    Micah
  8. May 21, 2010 at 10:55 PM
    MicahTheProphet
    Indiana
    00 Tacoma
    Alright, I'm going to go with the 5100's for the shocks, as for new u-bolts, it doesn't look like I'm going to need them. The new leaf pack is only about 1/8 inch thicker than the stock springs.
    I'm going to order the extended brake line since I have it replace it anyway.
    I haven't decided on new shackles yet, I gota see how bad the old ones are first.
    My question remains. How is 2.5" to much lift in the back?:confused: You have peeked my curiosity. Don't leave me hanging here. I want to know.:)
    Thanks
    Micah
  9. May 22, 2010 at 3:19 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    the ubolts dont need to be replaced because of length,they need to be replaced because ubolts dont last forever.they lose their strength and are something that should be replaced after removing them.
