Specs on Map light socket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2ndchancetoyotas, Oct 14, 2013.
  1. Oct 14, 2013 at 10:56 PM
    2ndchancetoyotas
    2ndchancetoyotas [OP] Well-Known Member
    Greg
    AZ
    Rebuilt
    So, there's lots of people who've bought LED map lights. I got to various websites and get lost on specs of diameters, lengths, etc. vs. what will fit. So I decided to take some measurements. I hope what I've found will help others decide just what 194 LED's you want to buy.
    Stock 194 bulb I measured:
    24mm length
    10mm diameter
    Max possible dimensions:
    36 mm length +or- 1mm (tough to measure without cutting hole in lens)
    12mm diameter hole in reflector
    13mm from base of socket to lip of reflector (i.e. this amount is behind the reflector)
    So to note, if part of the diameter of an LED that is larger than 12mm is built past the 13mm socket depth, it might fit.
    Dome light specs:
    38mm total stock length
    22mm between retaining/power clips
    Most other bulbs seem to not be such an issue. Enjoy
