Specs to fit 285 70 17 with no cmc?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lamb_of_the_freefolk, Aug 19, 2019.
  1. Aug 19, 2019 at 5:18 PM
    Lamb_of_the_freefolk [OP] Well-Known Member
    Simcoe County, Ontario
    2014 TRD Sport DCLB 4x4
    Bilstein 6112/5160, Icon progressive AAL, JBA UCA, BFG KO2's, Method MR305 NV Bronze, Baja Design WC fogs, Prinsu Cabrack
    I have heard you can avoid a cab mount chop for 285 70 17 tires, without any rubbing, with the proper offset/bs, lift, caster alignment. What would that sweet spot be? Are the specs for 2nd and 3rd gens different from each other?
    Btw, I'm running wheels with 0 offset and 4.75 backspace.
  2. Aug 19, 2019 at 5:31 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    If you wheel you're going to rub regardless of offset/wheel width/alignment specs and a lift isn't going to solve it since the wheel is taking the same path when you cycle the suspension on a stock and lifted truck (the limiting factor is the wheel well opening).
  3. Aug 19, 2019 at 5:47 PM
    Now that I look back, I did hear this from a mall crawler enthusiast so makes sense.
    Would still be nice to see what those pavement princess specs are. My rig will probably see 90% of its lifetime on pavement anyways. Other 10% on mild trails at most.
  4. Aug 20, 2019 at 5:12 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    2015 prerunner daily driver. 3” Toytec lift, jba ucas, 17x8.5 -10 offset. 285/70/17 Nittos. Caster is set at 4*. No rubbing on the pavement or roads I take to hiking areas.
