Spedometer Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by ruffrider, May 11, 2009.
  1. May 11, 2009 at 9:17 PM
    ruffrider
    ruffrider [OP] Member
    1997 toyota tacoma
    Hi Im new to this forum but i just bought a 1997 tacoma it was fine when i drove it but today i was driving about ten miles per hour and the spedometer told me i was going 40mph im wondering why its doing that i did some googleing and i seem to think its the speed sensor can anyone elabarate thanks
  2. May 11, 2009 at 9:28 PM
    98yota
    98yota Mean Green Machine
    Marion, VA
    4WD Timberland Mica taco
    CAI, gutted cat, bed cover.
    it may not be your speed sensor. check your fuse (should be a 5 amp i think) and see if its busted. if not, its more than likely your speed sensor.
  3. May 11, 2009 at 10:04 PM
    ruffrider
    1997 toyota tacoma
    which fuse would be looking for and were inside the car or under the hood
  4. May 11, 2009 at 10:14 PM
    98yota
    Marion, VA
    it should be under the dash to the left towards the drivers side door. i hope this helps, dont know exactly which one it is..better off to check them all anyways haha
  5. May 12, 2009 at 2:54 AM
    ruffrider
    1997 toyota tacoma
    ok and if its not that then its the speed sensor correct and were would i find the speed sensor thanks for your help
  6. May 12, 2009 at 8:32 AM
    98yota
    Marion, VA
    your speed sensor is located at the very back of your tranny, where your driveshaft connects to the tranny. no problem dude, i hope this fixes your problem. if thats not it, i think your sensor runs to the ECU then to the gauge cluster, thus having a speed limiter. that would be the only other 2 things i could think of. good luck!
  7. May 12, 2009 at 4:58 PM
    ruffrider
    1997 toyota tacoma
    im also wondering if the speed sensor went bad would it throw a check light
  8. May 13, 2009 at 8:59 AM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    My speedometer, tach and odometer stopped working and it threw the speed sensor code, so i checked the speed sensor and it is fine so i've been stuck there for the last month, don't know were to go from there!
  9. May 13, 2009 at 12:22 PM
    ruffrider
    1997 toyota tacoma
    ya mine didnt throw any codes so i dont know what to do besides change the speed sensor.
