Speed bleeders vs motive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ARB1977, Mar 17, 2021.
  1. Mar 17, 2021 at 12:43 PM
    ARB1977
    ARB1977 [OP] It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    What are your thoughts on speed bleeders? My motive bleeder took a dump today, 10 years old. Since my brake system is vacuum assist is there any tips. My beloved 2002 was the same without abs. Thanks.
  2. Mar 17, 2021 at 1:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Speed bleeders help if you are a one man show.
    I don’t know what psi it takes to “open” the speed bleeder.
    I have never used them with a pressure bleeder. A pressure bleeder might not have enough pressure to open the check ball in the speed bleeder. But I would think it should?
    In short, I don’t run them on my truck.
    Because I have a brother.
    And he’s doing just fine pressing the brake pedal for me while I bleed the brakes.
    Accipiter13, Jimmyh and whatstcp like this.
  3. Mar 17, 2021 at 2:02 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    You mean one that doesn't stomp the brake pedal as if it were....a mess of cockroaches? If so, I'm jealous.
    Sometimes it's tough being the only one with any semblance of mechanical sense/ inclination.
    Do whatcha gotta do to git-r-duuuuuun.:thumbsup:
    TnShooter[QUOTED] likes this.
  4. Mar 17, 2021 at 2:25 PM
    ARB1977
    North Texas
    Thanks man.
  5. Mar 17, 2021 at 2:27 PM
    ARB1977
    North Texas
    Thank you sir.
    TnShooter likes this.
  6. Mar 17, 2021 at 2:27 PM
    ARB1977
    North Texas
    Thank you sir. The motive worked well on my 2002. Haven’t tried it till today on my 15. The rubber hoses crumbled and the nipple to the bottle broke. I may get another.
  7. Mar 17, 2021 at 2:33 PM
    TnShooter
    Deogee
    STOCK
    You aren’t doing it right if you don’t use both feet to press the pedal.
    You know you did it right when the pedal hits the firewall. :rofl:
    Nahh, my brother is pretty good with this kind of stuff.
    Larzzzz[QUOTED] likes this.
  8. Mar 17, 2021 at 2:33 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    I have had a set on my Wife's Prius for 9 years now and they work great. I fill the caps on the Truck and Car with Fluid Film and they look brand new every time I do a bleed. I am a sick individual and do a brake bleed every year just cause what else am I going to do during the winter.
    I equate Speed Bleeders to a Fumoto Valve. There is always going to be the nay sayers. They will have never owned them and will swear they are worthless or too much money for what they are. By myself with only a single wrench and tube can bleed my brakes. I saved money the first time and 7 years later changing the fluid every year I am at what a dealer would have charged me for the first fluid change. Just saying.
    Rob MacRuger likes this.
  9. Mar 18, 2021 at 6:59 AM
    ARB1977
    North Texas
    What brand and do you use for your truck? So how many pumps do you do? Do you have the the hose submerged in brake fluid or is it not necessary?
  10. Mar 18, 2021 at 8:26 AM
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    I use the Russell(Edelbrock) and they were worth every penny; it's nice not having to go recruit someone to help with what I can do by myself. As far as having the hose submerged...nope. The hose is just there to direct the fluid into a catch container; the speed bleeder is just a check valve for your brake system, really. As far as "how many pumps"...1370 posts and you haven't learned what asking a question with certain terms is going to get you on TW? I'll let the creatives jump in on that one, but I will say that I don't ever expect to get brake bleeding down to such a science where it's a very set amount each time. Just push fluid through the lines and check the catch hose to see the color of the fluid. Fluid that needs to be changed is noticeably darker than champagne colored new fluid.
  11. Mar 18, 2021 at 10:32 PM
    Regnar
    Kodiak,AK
    I use Russell’s that I bought off Amazon. As for pumps I don’t get the “Color Change” because of doing it often but I will suck out the reservoir fill it up to the top. Pump out the back right until I get low. Fill all the way to the top and pump it out with the remaking until I get to the full mark. Usually takes me about 10 minutes. Probably 2 of it is remembering where I put the hose.
  12. Mar 19, 2021 at 1:42 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I was just looking these up as I am considering between these and a Motive Pressure system.
    What I saw is that the correct sizes for the bleeders are:
    https://www.tacomaworld.com/threads...oad-with-speed-bleeders.368080/#post-10043425
    Steel:
    SB7100 (Front Disk brakes) M7 x 1.0 x 35.15
    SB1010 (Rear drum brakes) M10 x 1.0 x 34.44
    Stainless Steel:
    SB7100-SS (Front Disk brakes) M7 x 1.0 x 30.22
    SB1010-SS (Rear drum brakes) M10 x 1.0 x 31.35
    PzTank, Micbt25 and TodayWasTHeDaY like this.
  13. Mar 19, 2021 at 5:07 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    A cheaper alternative to the Speed Bleeders is the Motion Pro bleeder 08-0143. It accomplishes the same as the speed bleeders, but only one is needed and moved from wheel to wheel.
    outxider, TnShooter and Jimmyh like this.
  14. Mar 19, 2021 at 5:44 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I have a couple different pressure bleeder kits at work. They're not that expensive. Also makes it an easy 1 man job
  15. Mar 19, 2021 at 1:06 PM
    ARB1977
    North Texas
    You don’t know by chance the part numbers? I looked on their site and they don’t list them for Tacoma.
    Jimmyh likes this.
  16. Mar 19, 2021 at 4:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I noticed that too. Just the older Toyota vehicles.
  17. Mar 19, 2021 at 5:36 PM
    TnShooter
    Deogee
    STOCK
    Here is the best I can do for the Russell Bleeders
    You could use the number JimmyH listed to compare them
  18. Mar 19, 2021 at 6:11 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I'm curious about what "adapter" you used for the MC? I just received a Power Probe BA10 adapter for the small Toyota cap and will mate it with a Motive Power Bleeder. I'll be using this on our 2015 Sport.
  19. Mar 19, 2021 at 9:08 PM
    Regnar
    Kodiak,AK
    I have 639560 and 639570 in the Truck.
  20. Mar 22, 2021 at 6:31 AM
    ARB1977
    North Texas
    I have that adapter. I was going to use the universal adapter that came with my motive only because I didn’t have the connections for the power probe. Ended up not bleeding the brakes after the hoses crumbled. Just refilled the mc.
