Speed bump clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jafrisi, Feb 23, 2018.
  1. Feb 23, 2018 at 7:48 PM
    jafrisi
    jafrisi [OP] Well-Known Member
    Tucson, AZ
    14 Superwhite DCSB TRD OR
    Toytec bilstein 5100 lift w AAL. 2.5 front and 1.5 rear. KMC turbine wheels 4.5 bs, BFG KM3s 285/75/16
    Ok so I'm getting the speed bump clunk when I go over the backside of speed bumps with speed. I have 5100s and 2.5 lift in front. Is the clunk from the 5100s or the stock uca? Which is maxed out?
  2. Feb 23, 2018 at 7:51 PM
    Pigpen
    Dan
    Northwest Montana
    It's a speed bump. Drive over it slower
  3. Feb 23, 2018 at 8:34 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    FIFY :D
    Avsfreak18 and Pigpen[QUOTED] like this.
  4. Feb 23, 2018 at 9:01 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Sway bar still on?
    nickj604 likes this.
  5. Feb 23, 2018 at 10:36 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Is it your mud flaps rubbing against the speed bump?
  6. Feb 24, 2018 at 7:33 PM
    jafrisi
    Tucson, AZ
    Sway bar on and relocated. Checked that already and its not hitting.
    No front mudflaps.
  7. Feb 24, 2018 at 7:48 PM
    Pigpen
    Dan
    Northwest Montana
    Clunking on compression or extension of shock?
  8. Feb 24, 2018 at 7:50 PM
    @old.man.adventures
    @old.man.adventures Well-Known Member
    2015 DCSB
    Icon Stage 4 Delta Joint
    Mine ended up being the factory "skid" plate below the radiator. Try tightening the bolts.
    tcjacado likes this.
  9. Feb 24, 2018 at 11:20 PM
    jafrisi
    Tucson, AZ
    Its on the downtravel for sure. I have heard of the 5100s topping out, but that seems so lame with just a 2.5 lift I just don't want to believe it. The stock uca are near their limit too but they do have more droop...maybe not enough.
    Definitely not the skid plates though, its a heavy thud.
  10. Feb 24, 2018 at 11:22 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Is your uca hitting your coil on down travel?
  11. Feb 24, 2018 at 11:30 PM
    jafrisi
    Tucson, AZ
    Does not appear to be, no. There are no marks indicating any contact, but I should put some tape or paint to double check.
  12. Feb 24, 2018 at 11:32 PM
    jafrisi
    Tucson, AZ
    There are threads talking about it, but super old and more ome related. Also they don't have stock uca.
  13. Feb 24, 2018 at 11:32 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Sway bar is hitting your springs. Get under your truck and look for rubbing marks on your springs.
    Running Board Man likes this.
  14. Feb 24, 2018 at 11:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Over Speed Bump Goes Clank
    Kyitty likes this.
  15. Feb 25, 2018 at 8:02 AM
    jafrisi
    Tucson, AZ
    No its not. Its been relocated and is not hitting. I put paint and tape to check for any contact already.
  16. Feb 25, 2018 at 8:03 AM
    jafrisi
    Tucson, AZ
    Oz...are you referrencing the old thread about this?
  17. Feb 25, 2018 at 8:06 AM
    jafrisi
    Tucson, AZ
    Its definitely something happening on downtravel. Either the shock topping out or the uca maxed droop.
  18. Feb 25, 2018 at 8:09 AM
    jafrisi
    Tucson, AZ
  19. Feb 25, 2018 at 8:53 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I found out when I put my coilovers on with a sway bar relocate that the sway bar was hitting to front skid plate supports. Was really bad on down travel. Saw the scrapes after a couple days of driving. So removed the sway bar and thud was gone.
  20. Feb 25, 2018 at 9:30 AM
    jafrisi
    Tucson, AZ
    Where was it hitting? Can you show a few pics? Based on the feel and thud sound I don't think it's the skid plate but I'm open to anything.
