Speed bump clunk.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jun 1, 2023.
  1. Jun 1, 2023 at 4:47 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Probably dumb question but do you guys ever get a clunk in front end if you hit a speed bump too fast? This one particular speed bump in my neighborhood is huge sometimes I hit it to hard and the truck nose dives and I hear a clunk occasionally? Normal? I guess I can’t expect suspension to be completely quite on bumps like that lol.
  2. Jun 1, 2023 at 5:49 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You most likely are bottoming suspension out hitting it hard, aka hitting bump stops.
    Gfenza89[OP] likes this.
  3. Jun 1, 2023 at 5:52 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    totaled
    part out
  4. Jun 1, 2023 at 8:56 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
  5. Jun 2, 2023 at 3:21 AM
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
    I had the same problem with mine. Turned out the front body mounts were shot with 7000 miles on the truck. It was a metal on metal clunk/screeching noise
  6. Jun 2, 2023 at 4:33 AM
    RI_OR21
    RI_OR21 Well-Known Member
    RI
    21 TRD OR/DCLB Army Green (1st Taco)
    Also have a 21 TRD OR and occasionally get a clunk/screech as you mentioned. May have Toyota check it out while I’m still under warranty. Thanks for the heads up about the body mount(s).
  7. Jun 2, 2023 at 4:41 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Mine did the same and it was worn core support bushings. Replaced under warranty, then those failed, too. After that I replaced them with 2nd gen energy suspension bushings and no problems since.
  8. Jun 2, 2023 at 7:07 AM
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
    This happened to me too and there were 2 reasons mine was making the noise.
    1. My LCA and bushings were torn and leaking (due to age).
    2. My catalytic converter shield.
    Given that yours is much newer than mine, these probably aren't your reasons. LOL
  9. Jun 2, 2023 at 7:45 AM
    jego
    jego Well-Known Member
    2020 TRD Off Road DCSB
  10. Jun 2, 2023 at 7:45 AM
    jego
    See the link above. It's a common problem that looks to have a solution.
