speed detector wire
Discussion in 'Audio & Video' started by 06TRDbama, Nov 28, 2007.
  1. Nov 28, 2007 at 7:41 PM
    06TRDbama
    06TRDbama [OP] Well-Known Member
    Maryville, TN
    06 Prerunner TRD Sport
    I got my eclipse navi/dvd unit in recently, and everything worked out great, but i cant find the damn speed sensor wire. i have seen several people say its the purple with white stripe in the black plug under the fuse box or behind the glove box, but i can not narrow it down. i can see several purple/white wires, but only one black plug below the fuse box and it doesnt seem to have the right number of pins. behind the glove box, there is ABSOLUTELY NO slack in the wires to splice into....any help/pics/suggestions? thanks guys
  2. Nov 28, 2007 at 7:52 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
  3. Nov 28, 2007 at 7:56 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    I think thats a question to take up with pb2themax , I know that he has an Eclipse Nav/DVD unit. Hope that helps.
  4. Nov 28, 2007 at 8:00 PM
    The_Hodge
    SC
    Speed Sense purple/white fuse box, black 13 pin plug, pin 5
    Note: Also found at the ECM behind the glove box, second plug from the bottom, pin 8
    this will work for any headunit requiring a speed wire
  5. Nov 28, 2007 at 8:27 PM
    06TRDbama
    Maryville, TN
    thanks for the replies guys but i have seen that stuff many times...i was hoping for a little more insight. has anyone else had the problem? like i said, there is only one black plug near the fuse box and it has like 8 or 9 pins...everything behind the glove box is extremely tightly wrapped up...i will give it another look tomorrow..thanks again
  6. Nov 29, 2007 at 2:39 PM
    The_Hodge
    SC
    find the second plug from the bottom behind the glove box, pull it out, and then just use a vampire tap on that wire. may need to cut back some tape/protectant to get some room to tap it.
  7. Nov 29, 2007 at 7:30 PM
    06TRDbama
    Maryville, TN
    thanks man...i didnt think of actually disconnecting any of these plugs..the reverse wire was easy and didnt require it. worked like a charm..
  8. Nov 29, 2007 at 7:32 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    What's the point of connecting it to the speed wire? Navigation purposes?
  9. Nov 29, 2007 at 8:09 PM
    The_Hodge
    SC
    it helps the detailing of the NAV and w/ my n1, it has a setup for digital gauges on screen, so it'll give u the mph down to the tenth.
    EDIT: for the pioneers, its not a necessity, but it helps
  10. Nov 29, 2007 at 8:20 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I figured you could use the GPS for that.
  11. Dec 3, 2007 at 8:06 AM
    06TRDbama
    Maryville, TN
    yea its not a necessity with any of them i dont think, but makes it more accurate, plug mine gives me a "check speed pulse wire" message every now and then
  12. May 22, 2011 at 5:38 PM
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Having trouble finding this damn wire.
    Reverse Light red/white + driver kicker pannel, gray 12 pin plug, pin 1
    *Also found at the ECM behind the glove box, second plug from the bottom, pin 8.
    Fuse Box:
    I see a Purple / White Stripe wire in a black plug but it doesn't look to be in PIN 5?! It looks like it's in the very bottom right pin of the black plug on the left.
    Alternate location behind glove compartment, on ECU.
    Which one is the ECU? (white or black box)
    Which one is the second plug? The second including the empty socket?
    If the black one then I do see a purple / white coming out of the plug second from the bottom. Is this it?
    I think I've got to the red /white stripe wire found behind the kicker panel.
  13. Aug 24, 2011 at 1:15 PM
    hcoulby
    hcoulby Well-Known Member
    Barry
    Baltimore
    TRD Off Road
    Were these wires the right ones? I want to make sure before i butcher my baby.
  14. Aug 24, 2011 at 1:48 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    The wire in the first pic for the speed (VSS) wire is correct, personally verified on a 2011 double cab. Haven't hooked up a reverse wire.
  15. Aug 26, 2011 at 8:44 AM
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    My speed sensor is not working (bad bite I think) but the reverse wire is working perfect.
  16. Aug 27, 2011 at 12:07 PM
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    Not sure if this would be helpful but I snapped this picture of the speed sensor wire I had to run to my amp after I upgraded my head unit. My original post here.
  17. Apr 13, 2012 at 5:52 PM
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    The purple / white stripe wire behind the drivers side fuse panel is DEFINATELY not the speed sensor wire on a 2005 v4 Access Cab. 3rd attempt this time I soldered the wire and still nothing. Lastly I hooked up a multimeter and was getting at most 50 millivolts from it and it never wavered driving around the block.
    I don't have a JBL system and my wires don't look like that last picture above. There are tons of purple/white wires behind the glove compartment.
    The Tacoma service manual for 05/06 talks about some yellow/red wire, but I don't see that either. WTF!?
  18. Apr 13, 2012 at 6:24 PM
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
  19. Apr 14, 2012 at 1:41 PM
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Ok so that is it... It's the purple / white stripe wire. Not the solid purple wire just above it.
    Thanks!
  20. Apr 15, 2012 at 6:58 AM
    fbconvert
    Brian
    Seacoast, NH
    Yeah in that picture I photoshopped a solid purple wire and then didn't say anything about it being purple with white stripes. I can see how that would be confusing. Glad everything worked out for you at least.
