speed limit question
Discussion in 'Law Enforcement Officers' started by MTgirl, Oct 12, 2011.
  1. Oct 12, 2011 at 8:53 AM
    MTgirl
    MTgirl [OP] too many frogs, not enough princes...
    Weesa
    in the forest
    99 - 3.4L V6 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    I've been searching through the MT state traffic regs for awhile this morning and I'm not finding the info I was hoping to. I assume other states would have similar regs so maybe you guys can help me out.
    We all know there are speed limits stating the maximum allowed speeds - in MT 75 mph on divided highways/interstates and 70 on 2-lane highways - but is there such a thing as a minimum speed limit? Driving too fast can be dangerous and hazardous but so can driving too slow... All I can find in the MT regs is this:
    61-8-311. Minimum speed regulations. (1) A person may not drive a motor vehicle at a speed slow enough to impede or block the normal and reasonable movement of traffic except when reduced speed is necessary for safe operation or in compliance with law.
    (2) On a two-lane highway where passing is unsafe because of oncoming traffic or other conditions, the operator of a slow-moving vehicle behind which four or more vehicles are formed in line shall turn off the roadway at the nearest area where a sufficient and safe turnout exists in order to permit the vehicles following it to proceed. If the shoulder of the highway to the right of the slow-moving vehicle is wide enough and is in a condition allowing safe travel, the operator of the slow-moving vehicle may drive onto the shoulder and proceed at a safe speed until passed. As used in this section, a slow-moving vehicle is one that is proceeding at a rate of speed less than the normal flow of traffic at the particular time and place. The department of transportation is authorized to designate and construct turnouts and to erect official traffic control devices at appropriate places advising motorists of this statute.
    (3) If the department of transportation or local authorities within their respective jurisdictions determine on the basis of an engineering and traffic investigation that slow speeds on any part of a highway impede the normal and reasonable movement of traffic, the commission or the local authority may set a minimum speed limit below which a person may not operate a vehicle except when necessary for safe operation or in compliance with law.
    The reason I'm hoping to find out more info on this is that I keep coming across these European RV's - I think they call them overland trucks (?) - made by Mercedes. They are all licensed with foreign plates so I'm assuming that there are certain regulations that would apply only to them and they need to meet certain requirements before being allowed on US roadways. These behemoths are becoming more common around here on the roads leading to Yellowstone National Park. The problem is that they can only seem to travel at a maximum of 40 mph (I've gotten caught behind 3 in the last couple of months and each time its a maximum of 40 mph) and the roads to the park are two lane and very curvy so there is not a lot of safe areas to pass other vehicles. Traffic backs up very quickly and people start passing on corners, etc and in general it seems like an accident is imminent.
  2. Oct 12, 2011 at 8:55 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    2001 4x4 5Spd Xtra Cab V6
    205k+ miles, 265/75/16 BFG A/T's, OME 881's, Wheelers 5 leaf pack, 5100's, Home Made Sliders
    I know for a fact there are minimum speed limits on most interstates (I think Oklahoma actually has the min speed limit posted).
  3. Oct 12, 2011 at 8:56 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Not sure if this helps but on the Interstates in Arkansas, Missouri and Oklahoma there were Minimum Speed Limits posted along with the Maximum Speed Limits (I believe the minimum was 40).
    Fink[​IMG]
  4. Oct 12, 2011 at 8:57 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Alabama has a minimum posted speed limit of 40mph on all of our interstates.
  5. Oct 12, 2011 at 8:57 AM
    D13
    D13 Well-Known Member
    D
    Moving all the time
    08 TRD-OR
    Tinted windows, Plasti-dipped emblems (black), white 2011 grill w plasti derped white toyota emblem, Weathertech dontfits; Clarion HU, Hertz-165 Coax, Alpine 500w mono to 8" JL 3w3, Wet Okeles, CBI sliders, Eibach/5100's @0.85 in front, Dakar leaves and OME shocks in rear, Leer topper.
    Yes there is a such thing as a minimum speed limit. I've seen them posted in some areas.
    I dont think there is any across the board minimum though.
    From what i remember from my years ago drivers ed.. its any disruption to the flow of traffic.
    I worked in a tourist area as well and had similar issues with large slow vehicles not using the pull outs and causing and issue. Perhaps you could talk to the local law enforcement?
  6. Oct 12, 2011 at 8:58 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I'm not a LEO but Wisconsin used to post max speed & min speed (10mph under max) I don't know if they still do. That's the only place I've seen it posted.
  7. Oct 12, 2011 at 9:00 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OME suspension, ARB Air Locker, Yaesu FT 8900 Ham Radio
    The minimum you're looking for is only on 4 lane limited access freeways, and you're talking about speed (or lack thereof) on 2 lane roads.
  8. Oct 12, 2011 at 9:03 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah the tourists always drive 20mph through the small town im from because of the chili/pumpkin farms and the corn maze in october. Makes me angry because the road is 4 miles long with no passing what so ever so these retards will have about 1 mile of traffic backed up behind them without a care in the world.
    Ill admit I have honked at them and motioned to get out of the way, not proud of that :laugh:
    so... I feel your pain but I doubt there are laws regarding min speed on small back country roads.
  9. Oct 12, 2011 at 9:04 AM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i did not read word for word. but i se you are asking what the MINIMUM speed limit is. i know out side are bigger cities. the speed limits go from 55MPH to 65MPH in some places and even 70MPH. we have a law that state you must do no less than i think it’s 10 or 15MPH under the posted speed limit. example. if the posted speed limit is 55MPH you have to do 45MPH, if the speed limit is 65MPH you must do at least 55. and so on. (thats going on a 10MPH minimum. but it may be 15. and i know is some places. that it is 65MPH BUT it is still posted 55MPH for trucks. it is like this in the county i live in. wear it’s 65MPH or cars,suvs and any class D or class M license. but CDL have to do 55.
  10. Oct 12, 2011 at 9:04 AM
    D13
    D
    Moving all the time
    08 TRD-OR
    Other roads have minimum speed limits too, not just 4 lane limited access freeways.
  11. Oct 12, 2011 at 9:05 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    In SC they have a sign that says "Speed Limit 55" and then usually one under it that says "Min Speed 40", which is what it usually is, on the highways. The interstates like I95 usually have it a 50 or so with a max of 70.
  12. Oct 12, 2011 at 9:07 AM
    Fink
    Orlando, FL
    Back when I was a firefighter/EMT, we would call in vehicles going below the Minimum Speed Limit on the Interstate if it ended up impeding our response.
    I only heard of one person getting ticketed for it. I probably called in close to 15 or 20 of them in the four years I worked there.
    Fink[​IMG]
  13. Oct 12, 2011 at 9:10 AM
    slmgt
    slmgt Well-Known Member
    San Francisco Bay Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr) Hose clamp securing tailgate
    In California, the speed limit signs posted tell you the minimum speed, because if you're not going faster than that, good luck!
    California drivers...
    :rolleyes:
  14. Oct 12, 2011 at 9:32 AM
    KenLyns
    KenLyns Lord of War
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Front Bumper, CBI Sliders, Icon ET Coilovers, aFe Intake, Icon VS Rear Shocks, TSB Leafs, Timbren Bumpstops, All-Pro UCAs, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps, Deeza HD Sway Bar Links
    I think the intent of the law is clear - you can drive slowly as long as you don't impede traffic, with "traffic" defined as four or more vehicles. On a two-lane road there's not much you can do, and European drivers deal with it all the time. The car drivers just need more passing discipline (and skill). Got to use the V6 and swaybar some time, right?
  15. Oct 12, 2011 at 9:34 AM
    tacoman15
    tacoman15 Stop staring at me swan!
    Western NC
    In the state of Georgia the minimum speed limit is posted on the highways which is 40 mph and I am pretty sure NC is the same way
  16. Oct 12, 2011 at 9:36 AM
    MTgirl
    Weesa
    in the forest
    99 - 3.4L V6 4WD
    I was caught behind one of these RV's this past Sunday....me and 14 other vehicles! The driver of the RV was obviously not aware of the regulations.
  17. Oct 12, 2011 at 9:38 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    something i do. is IF someone is going slow and i fill unsafe on a 2 lane road behind them. i will pass when i fill it is save to do so and i can see oncoming traffic and KNOW i have the space to pass. even if it is not a passing sone and there are double solid yellow lines. but ONLY if i don’t fill safe be hind the person and i KNOW i can make a safe pass. brother also told me i should do this and he is a cop.
  18. Oct 12, 2011 at 9:45 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    08 TRD Sport
    5100's @ .85, Custom Grill, Debadged, Bestop Supertop, BHLM, DDM 4500k HID heads, Nokya 2500k fogs, LED interior lights, Weathertech Mats...
    CT has minimum speeds posted below speed limit signs on most highways
  19. Oct 12, 2011 at 9:53 AM
    whippersnapper02
    whippersnapper02 Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    I believe there is no official minimum in CA but if you go too slow you will get pulled over for impeding traffic.
    Posted via :sandwich:
  20. Oct 12, 2011 at 9:56 AM
    D13
    D
    Moving all the time
    08 TRD-OR
    I worked in a tourist area.. had to pass a lot on double solids... didnt like it, but it was safe if you are going 15mph (30 below posted limit)
    The worst I've ever experienced was a caravan of the large bus type super luxury motor homes, about 30 or so.. going literally 15mph and not pulling over at all, and leaving barely any space between them for passing cars. I think I lost a good portion of my hair that day. my point - i feel your pain MTgirl
