Speed / Odometer deviation with re-gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Nov 23, 2011.
  1. Nov 23, 2011 at 6:02 AM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    When I re-geared from 410 to 456 I had the following deviations in MPH and Odometer readings.
    Speedometer Actual
    55mph 50mph
    65mph 59mph
    70mph 64mph
    75mph 69mph
    80mph 73mph
    85mph 78mph
    Odometer Actual
    26.3 miles 25 miles
    52.6 miles 50 miles
    105.2 miles 100 miles
    I have been told that by re-flashing the ecu these values could be calibrated. Called my tech at toyota and he states that toyota only has the ability to re-flash to factory settings. If anyone has any suggestions how to calibrate it would be appreciated.
  2. Nov 23, 2011 at 6:05 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I am actually a lot more off than you and I have 315's, Idk why I am so Dar off but when I read 75 I'm around 67. I don't think there is a recal for our trucks,
  3. Nov 23, 2011 at 9:51 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    That would make sense. I only have 265's. Whenever you change gears it throws the calibration off due to rpm's not being the same as factory. This is why you have to find someone that has the equiptment to re-flash the ecu
  4. Nov 23, 2011 at 9:53 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
  5. Nov 23, 2011 at 10:04 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Why is your speedo higher than actual but the odometer is lower than actual?
  6. Nov 23, 2011 at 1:25 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Our spedo's and odo work of electronic mapping in the ecu. If you change tire size or gearing it throws it off. The spedo thinks vehicle is travelling much faster than it actually is which also registers more miles than you are actually travelling.
  7. Nov 23, 2011 at 1:30 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Right but yours is registering slower, but giving higher miles. They should both be higher or lower. Example your speedo says 55mph but your actually going 50mph (your stats). If you drive for one hour your odometer should read 55 miles but you actually went 50 miles
  8. Nov 23, 2011 at 1:34 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    With bigger tires it should read slower than you are actually going
  9. Nov 23, 2011 at 1:36 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Wow your right got my values reversed on the odo. Thanks Ill switch them.
  10. Nov 23, 2011 at 2:09 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    It is the Re-Gear that is throwing things off. When I changed tire size from 245 (stock) to 265 it actually make my spedo correct ( spedo was off with the 245's). As soon as I re-geared it created the discrepency
  11. Nov 23, 2011 at 2:15 PM
    cummins6speed
    Yes, a regear will make the speedo read higher, but the guy I quoted did not mention re-gearing his so his speedo should read low
  12. Nov 23, 2011 at 2:15 PM
    cummins6speed
    The wheel speed sensors are for the ABS, the speedo sensor is in the transmission
  13. Nov 23, 2011 at 2:20 PM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2010 DBLC 4x4 Off Road
    Sorry it's off topic but where are the 410's? Selling them?
  14. Nov 23, 2011 at 2:21 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Although others may disagree, I'm pretty sure the speedo and odo come from the tranny (at least in the manuals). I think the speed sensors on the wheels are used primarily for the ABS. I'm a 5-lug with 31 inch tires and I replaced the speedo gear in the 5spd when I regeared to 4.10's. My speedo reads correct now. Unfortunately there isn't a gear for 4.56 gears that I know of and I don't think this works for the automatics.
  15. Nov 23, 2011 at 2:28 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    I have the 410's for the rear only. I got a complete front diff from ecg's so I had to return my 410 front diff to them.
  16. Nov 23, 2011 at 3:42 PM
    08pretaco
    Oliver
    az
    If you are rinning 4.56 and 265's you would be farther off than me, which is why I stated it is weird that you are reading closer/same as I am.
  17. Nov 23, 2011 at 4:14 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    dont know bro. Im running 265 75 16's I hooked up my gps which give a constant mph readout (which I assume is accurate) and comparing it to my spedo readout. Im turning just under 3100 rpms at a true 80mph
  18. Nov 23, 2011 at 5:04 PM
    08pretaco
    Oliver
    az
    My true 80 is about 2900 rpm
  19. Nov 23, 2011 at 5:26 PM
    08pretaco
    Oliver
    az
    Oh and mu speedo was reading something.like 95. Gps 16 miles, truck 15
