Speed pulse wire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Altec914, Nov 12, 2008.
  1. Nov 12, 2008 at 12:30 PM
    Altec914
    Altec914 [OP] ALTEC 914
    florida
    prerunner
    I'm installing a in dash GPS this weekend and I need to find the vehicle speed pulse wire location and what color it is. And if anyone knows if you don't hook it up to the GPS how much will it put you off.
    THANKS
  2. Nov 12, 2008 at 12:53 PM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    Reverse Light red/white + driver kick, gray 12 pin plug, pin 1
    Speed Sense purple/white fuse box, black 13 pin plug, pin 5
    There's a post somewhere on here with pictures showing the wires. I can't find it right now, but hope this helps.
  3. Nov 12, 2008 at 12:55 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Hmm curious what it does and why you need to find a Speed pulse wire? What brand Navi unit did you get. The aftermarket wiring harness, like comes with all head units from crutchfield should be all you need to do the install.
  4. Nov 12, 2008 at 12:57 PM
    trtripoli
    Denver, CO
    I have eclipse AVN6620. The speed pulse wire is to help keep track of your location when you loose direct connection to a satelite. Going into a tunnel for instance.
  5. Nov 12, 2008 at 1:03 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    wing it stud. it ain't like you're gonna get lost in a tunnel.
  6. Nov 12, 2008 at 1:06 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    ahh that makes sense, is that needed because the Navi is not a hard drive navi on the 6620?
  7. Nov 12, 2008 at 1:25 PM
    Altec914
    florida
    prerunner
    Thanks everyone for the info. I'm installing a Eclipse AVN5510 with back up camera,blue tooth and I-pod adapter.
  8. Nov 12, 2008 at 1:46 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
  9. Nov 12, 2008 at 1:51 PM
    trtripoli
    Denver, CO
  10. Nov 12, 2008 at 2:07 PM
    papabear050
    haha, yeah don't you hate that.
    Also the speed pulse will let the unit sense the speed of the vehilce and estimate arrival time to your destination. It is usually pretty accurate, dunno if it adjusts itself at lights but it's pretty on the money....well in the AVN6620 neways.
    Good luck.
