Speed sensor ?'s
Discussion in 'Solid Axle Suspension' started by tlevan03, Nov 30, 2015.
  1. Nov 30, 2015 at 4:27 PM
    tlevan03
    tlevan03 [OP] Well-Known Member
    tad
    So i got the dual cases in the truck. Using gear drive cases. I ordered the VSS adapter from TG. It converts the mechanical signal to electronic. On the first drive the speedo worked for about a mile. I pulled it all back off to ensure that it was all splined in. Drove it again, worked for about 1/2 mile. I had to use the extended speedo cable adapter because I cannot fit the adapter on the speedo drive because of the FROR crossmember. The only thing I can think of is that I have a bad VSS adapter. Ive looked around and cannot find any issues with them.
  2. Dec 1, 2015 at 10:06 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
  3. Dec 1, 2015 at 10:11 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
  4. Dec 2, 2015 at 4:01 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Same here... my Inch Worm VSS has never given me problems.
    Be sure to use heat shrink on the connections if you need to cut/ add wire.
    Good luck.
