Speed wobble
Discussion in '4 Cylinder' started by BCTOYOTATACOMA03, Feb 3, 2014.
  1. Feb 3, 2014 at 8:35 AM
    BCTOYOTATACOMA03
    BCTOYOTATACOMA03 [OP] Active Member
    Samuel
    Mission, B.C.
    2003 SR5 4x4 Access Cab
    Having some steering wobble at around 70 km/h (50mph). Driving straight and hands on the wheel, the steering wheel is shaking back and forth quite a bit. I am running 32" ATs on stock steering arms and such. Maybe the steering arm needs to be upgraded or replaced? Any help is great.
    Thanks.
  2. Feb 3, 2014 at 10:18 AM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    Start with the easy/cheap things first.
    Are your wheels balanced?
    I just had mine balanced and the 70 mph wobble went away.
  3. Feb 3, 2014 at 12:07 PM
    BCTOYOTATACOMA03
    Samuel
    Mission, B.C.
    Thanks going to get a balance and see.
  4. Feb 3, 2014 at 4:35 PM
    Fletch
    Fletch Well-Known Member
    John 14:6
    Orange County, Ca.
    Tacoma PreRunner
    maybe the steering wheel needs to be balanced. :D
  5. Feb 3, 2014 at 6:53 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Typically a wobble back and forth tends to be an alignment issue or bad tire wear.
  6. Feb 3, 2014 at 6:57 PM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    are your AT's p or LT rated?
    i went from passenger tires to light truck tires and it took that vibe i had away
  7. Feb 3, 2014 at 7:05 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If re-balancing tires don't help, then it could be any number of things, all of which could be check by parking on level ground, steering back and force, and observing the suspension/steering parts under the truck for play:
    - Worn tie rod ends
    - Worn lower ball joint
    - Worn steering rack bushings
    - Loose steering column intermediate shaft
    Most of these are possible to do yourself: http://www.tacomaworld.com/forum/1st-gen-tacomas/95271-1st-gen-diy-how-thread-compiled-list-helpful-links.html#post1820599
