Speedmaster (torson) 8" clamshell.. Anyone?
Discussion in 'Performance and Tuning' started by HRC4, Oct 15, 2020.
  1. Oct 15, 2020 at 11:43 AM
    HRC4
    HRC4 [OP] Member
    2020 Tacoma TRD Pro MT
    URD short shift kit 265 75 16 Goodyear Duratrac's
    Hey there,
    I am doing some parts searching for a torson LSD for our 8" front diffs, and came across this Speedmaster part.. Has anyone ever looked into it or purchased one? I've tried searching everywhere for any info on previous buyers or reviews, but had not much luck.
    I have seen some other parts reviews from this company and some people are really impressed, and others say stay away..? thoughts?
    https://speedmaster79.com/Toyota-IFS-Clamshell-8-30-Spline-TorqueWorm-LSD-Limited-Slip-Differential
  2. Oct 18, 2020 at 6:49 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    actually looks like a quality product
    specs are great
    really depends on why folks say ‘ stay away '
  3. Oct 18, 2020 at 10:43 PM
    HRC4
    HRC4 [OP] Member
    The only clip I saw was a guy in Aus saying the housing axle bores weren't the right size causing too much axle shaft movement in the case.. It does look well built IMO.
  4. Oct 19, 2020 at 9:00 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I know that the Raptor has a Torsen in the front but with low bias ratios ; 2.5 under load and 2.1 coast. Didn’t see those published here and it’s critical for the front. Too high a ratio and the truck will steer like crap
    HRC4[OP] and JustDSM like this.
  5. Oct 19, 2020 at 9:53 AM
    HRC4
    HRC4 [OP] Member
    Looks like they have needle bearings (which are a spec bearing so they will have to be a fixed bore size) in the case for the shaft supports.. probably a better solution than just a lathe bored case.
    whatstcp[QUOTED] likes this.
