Speedo accuracy question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rodallg, Oct 15, 2010.
  1. Oct 15, 2010 at 7:36 AM
    Rodallg
    Rodallg [OP] Well-Known Member
    CA
    My observations on my new to me 09 with the stock tires compared to my GPS shows the following. My speedo is about 2 mph faster than gps but the odo is the same after 32 miles and watching the 10ths of a mile roll over it was even. Any thoughts?
  2. Oct 15, 2010 at 7:40 AM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Newark, Delaware
    07 TRD Sport Access 6spd
    Hardwire GPS, 110v power outlet in cab, foglights anytime, mudflaps removed, pa-15 ipod interface, rear leaf tsb, URD short shift, integrated third brake/cargo light, ABS disable switch, BHLM, Dynomax super turbo muffler, Nitto Terra Grapplers 265/70/17, Front Bilstein 5100's at 1.75, Weathertech floormats, sockmonkey bedsides, bestop supertop, spidertrax
    Is it 2 miles faster at all speeds? because then your needle is just off. If it get progressively more off the faster you go, than the tire ratio is a little off. Sounds to me like needle adjustment.
  3. Oct 15, 2010 at 7:42 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Mines the same way and there have been threads on this. It seems like just the way the 2nd Gens were built. No idea why...
  4. Oct 15, 2010 at 7:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's normal..... the speedo needle (on the dash) is not calibrated properly to the numbers (per say).
    I have a Scangauge which takes the info directly off the ECU and the speed on the Scangauge is accurate to the GPS. However - the dial on the dash shows 2mph fast.
  5. Oct 15, 2010 at 8:24 AM
    Rodallg
    CA
    Great info, thank you.
  6. Oct 15, 2010 at 9:38 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Has to do with something about the computer converting the signal from digital readout (odometer) to analog readout (speedometer) makes it a small percentage off. Seems in this day & age of technology they could make it a more accurate conversion. Someone else said Toyota deliberately does it for safety because so many owners put on larger tires. But the odometer is accurate with the stock size tires, that's all I care about.
  7. Oct 15, 2010 at 9:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Bingo.
