Speedo calibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sky65, Oct 17, 2013.
  1. Oct 29, 2013 at 3:53 PM
    Sky65
    Sky65 [OP] Well-Known Member
    So here's where I am with the gear change. Remember the stock gear is 28 teeth. I tried a 29 tooth gear. It fit fine but the speedo went the wrong way! After I thought about it again it made sense. So I got a 27 tooth gear. The gear shaft is the same as the stock 28 I took out but the nylon gear itself is bigger. Too big in fact to install. Well now I have $40 in gears that won't work. I am going to try to cut down the 27 tooth gear to fit by putting it in a drill press and filing down the teeth.
  2. Oct 30, 2013 at 4:13 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I don't think I care about mine enough to mess with. I'm sure it'd be more worthwhile to people who have bigger discrepancy tho......let us know how it works out.
  3. Oct 30, 2013 at 4:15 AM
    iJDub
    iJDub Well-Known Member
    I had the same results.
