Speedo Discrepancy
Discussion in 'Wheels & Tires' started by mistermcgoo, Sep 8, 2021.
  1. Sep 8, 2021 at 10:04 AM
    mistermcgoo
    mistermcgoo [OP] Well-Known Member
    PA
    2021 Super White TRD OR DCSB
    I’m currently torn between either getting 16” wheels (-12) wrapped with 265/70/16 or 17” with 265/70/17’s on stock OR suspension, no level or lift.
    Does anyone happen to know how far off going with the 17’s would make my speedo? Would 75’s make it off much also?
  2. Sep 8, 2021 at 3:32 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Put in whatever sizes you want to compare.
  3. Sep 8, 2021 at 6:20 PM
    Haun0002
    Haun0002 Well-Known Member
    2020 TRD sport 6MT - MGM
    I personally found that going from stock 265/65r17 up a size to 265/70r17 made my Speedo more accurate. If I were you, I would download an app and measure current accuracy. I bet you find that your 1-2mph/kph off (low) at highway speeds.
    mistermcgoo[OP] likes this.
  4. Sep 9, 2021 at 8:10 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You’re assuming that stock your Speedo is correct which more than likely it is not. You need to first check if it’s correct or off and make your calculations from there.
