Speedo gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Dec 20, 2013.
  1. Dec 22, 2013 at 9:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IIRC, it was very easy to swap. Lost very little gear oil in the process. A teaspoonful. :notsure:
  2. Dec 23, 2013 at 11:27 AM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    The dealer is telling me that he cannot give me a different gear, that I have to go to a place and get it calibrated. He said toyota does not even calibrate them? Any thoughts? I think I'm going to take a ride down to the dealer tomorow. I hate dealing with the parts guys
  3. Dec 23, 2013 at 11:52 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    You can't calibrate it unless you buy an electronic module, told you they wouldn't sell you a gear, dealers are dicks like that. Figure out what tooth count you need and order it online. If you figure out how many teeth you need ill find you somewhere online to get it
  4. Dec 23, 2013 at 12:01 PM
    smmarine
    Melbourne FL
    You were right. They are. He said he had never heard of just swapping the gear. But basically I just need to pull mine, count the teeth, and then how to I figure how many teeth the new gear needs?
  5. Dec 23, 2013 at 2:48 PM
    bellassaiw10
    Currituck NC
    Yeapp get us the teeth number and we can figure out which one ya need the gear is the cheap part the speedo sensor is the pricey part
  6. Dec 23, 2013 at 4:37 PM
    smmarine
    Melbourne FL
    I'll pull it tomorrow and post. It's dark here florida at the moment and I was at work. But I got tomorrow off! How pricey we talking? I thot it as jus the gear you swapped, didn't know it was the whole sensor? But the 31s are worth it
  7. Dec 23, 2013 at 4:56 PM
    bellassaiw10
    Currituck NC
  8. Dec 23, 2013 at 6:06 PM
    smmarine
    Melbourne FL
  9. Dec 23, 2013 at 8:58 PM
    bellassaiw10
    Currituck NC
    Yeah you can just undo the little clip and the gear pops right off slide the new one on and bam
  10. Dec 24, 2013 at 6:24 AM
    smmarine
    Melbourne FL
    Ok. I found mine on the passenger side. Taking it out now
  11. Dec 24, 2013 at 6:33 AM
    smmarine
    Melbourne FL
    Counted twice. 17 teeth!
  12. Dec 24, 2013 at 7:30 AM
    bellassaiw10
    Currituck NC
    What size motor ?
  13. Dec 24, 2013 at 7:33 AM
    smmarine
    Melbourne FL
    3.4 liter. Stock 4.10 gears
  14. Dec 24, 2013 at 9:36 AM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    17 doesn't sound right. I think the smallest is 28 and largest was 35?
  15. Dec 24, 2013 at 10:48 AM
    #35
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    So I looked back at my build thread. I originally had a 28 tooth gear (which I still have if someone needs), and went up to a 32 tooth gear. This corrected my speedo that was ~ 13% fast to about dead accurate. So each tooth increase will decrease your speedo reading 3% and vice versa.
    I still don't know about that 17 tooth gear you pulled ......
  16. Dec 24, 2013 at 12:12 PM
    #36
    bellassaiw10
    Currituck NC
    He has a prerunner completely different sensor and gears which is why his count seems off
  17. Dec 24, 2013 at 12:32 PM
    #37
    smmarine
    Melbourne FL
    The guy at parts said he has 4 different gears of 17 teeth. Idk what gear I need though.
  18. Dec 24, 2013 at 12:35 PM
    #38
    bellassaiw10
    Currituck NC
    Are there any ID marks on the gear? Parts people really have no idea what they're doing even after you give them a vin haha
  19. Dec 24, 2013 at 12:46 PM
    #39
    smmarine
    Melbourne FL
    I didn't look. I'd have to pull it again. I stuck it back the tranny cause I had to drive
  20. Dec 24, 2013 at 12:52 PM
    #40
    bellassaiw10
    Currituck NC
    Take pictures of it cause parts guys need all the help they can get
