Speedo still not working...HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mambafan, Jul 30, 2012.
  1. Jul 30, 2012 at 4:08 PM
    mambafan
    mambafan [OP] Member
    Paul
    Central Valley, California
    06 Tacoma
    Lifted, Custom Rims and Tires, 2000 watt system, many other mods.
    Hey guys...I am still having the issues with my speed odometer not working, the brake, abs, and check engine light all on. :mad: Checked fuses. Pulled cluster out to check all connections. I don't understand because the tach works, but no speedo. WTH! PLEASE HELP!!
  2. Jul 30, 2012 at 4:19 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    that sucks, i can only state to check wires at the other end, at the t-case or tranny or wheels or wherever the speed sensor is. check the codes see if they say anything
  3. Jul 30, 2012 at 4:21 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    It is probably the IGN 1 or 2 fuse behind the little cubby hole.
  4. Jul 30, 2012 at 4:46 PM
    mambafan
    Paul
    06 Tacoma
    Well, I can't seem to find a speed sensor as crazy as it sounds. And I've checked IGN 1 and 2 fuses, both good. It wasn't recently lifted. I'm baffled!
  5. Jul 30, 2012 at 5:06 PM
    mambafan
    Paul
    06 Tacoma
    So if one goes bad, the speedo would stop working?? Those things aren't cheap!
  6. Jul 30, 2012 at 5:22 PM
    mambafan
    Paul
    06 Tacoma
    Greatttt...Thanks. Any clue to tell which one is bad??
  7. Jul 30, 2012 at 5:34 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    So your tachs still works right? All gauge lights work. Just where your mileage read out does not.
  8. Jul 30, 2012 at 5:41 PM
    mambafan
    Paul
    06 Tacoma
    That's right. Only the speedo and mileage is not working...
    Tach, temp, fuel gauges working. No codes on scanner.
  9. Jul 30, 2012 at 5:43 PM
    Blackshirts
    TX
    Stuff
    Did you do the gauge mod?
  10. Jul 30, 2012 at 6:00 PM
    mambafan
    Paul
    06 Tacoma
    Unsure what you mean about gauge mod...:confused:
  11. Jul 30, 2012 at 6:26 PM
    Blkvulcan
    Blkvulcan Well-Known Member
    Paul
    Augusta, GA
    12 Prerunner SR5
    I had the same symptoms on my '99 Ranger, it was the Vehicle Speed Sensor. Fortunately for that truck the part was $12 and took about 5 minutes to replace, one bolt held it on the differential. My friend had the same issue on his Chrysler 300, it had I think 3 sensors and they were expensive.
  12. Jul 31, 2012 at 12:42 AM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    I had a similar issue a while back, except my fan/ac, windows, interior lights, gage lights, and rear view auto dimming didn't work! I found that the 10A ign 2 (if I remember correctly) fuse had blown....i didn't see it until I actually pulled the fuse out and held it up to the light.....replaced the fuse and everything worked again
    It happened when I did my fog lights on anytime mod....I guess I shorted out that circuit when I accidentally stuck my jumper wire into the wrong connector.
  13. Jul 31, 2012 at 1:07 AM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I had that problem and I thought it was the wheel speed sensor, I took it to the dealer and it was the wire conected to it when i lifted it I guess i pulled on it a little too hard, it was only like 150 bucks to have them fix it, part was like 90 bucks, they allready had it in the shop so I justhad them do it for 60 bucks, problem fixed..
  14. Jul 31, 2012 at 1:37 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I just looked at the prints and it could be the IG1 Fuse or the connectors going to the ecu for the skid control etc and it could possibly be an issue with one or more wheel speed sensors.
  15. Jul 31, 2012 at 6:33 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    The techstream software would probably pinpoint which sensor was at fault and allow you to confirm there is nothing wrong with the gauge cluster by actuating each gauge needle and light if you wanted. Otherwise you can use the shop manual and multimeter to perform a resistance check on each individual wheel speed sensor.
    Hopefully none of the wiring got pinched when you go the lift installed...there are 2-3 various cable bundles in the rear, and the only protection is some flex loom.
  16. Aug 2, 2012 at 11:49 PM
    mambafan
    Paul
    06 Tacoma
    What is techstream software??
    ok, I just Google it. This is something a dealer or repair shop would have...which is whom I'm trying to stay away from!! lol
