Speedo & tach drop to zero
Discussion in 'Technical Chat' started by jimaple2, Mar 23, 2009.
  1. Mar 23, 2009 at 9:36 PM
    jimaple2
    jimaple2 [OP] New Member
    Colorado
    2000 SR5 TRD
    I have a 2000 TRD that has had this problem since I bought it new. It has increased in frequency and duration over the years. Now nearing 100k. Only one other person has actually seen it, but she is not a mechanic. lol. I'll be driving along, when all of the sudden, the tach and speedo drop to zero, the odometer display goes out as does the cruise control. Fuel & Temp guages are not affected. Then they just come back on, sometime in a few minutes, other times after several days. The check engine light comes on (sometimes), but then goes off. Never had a chance to get it read. Every time I had a mechanic look at it, it wasn't happening. They think I'm crazy. Anybody else seen/heard of this? Thanks!
  2. Mar 24, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check out the speed sensor connection under the truck. Make sure there is no broken wires.
  3. Mar 24, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And Welcome to TW!! :)
  4. Mar 27, 2009 at 6:47 AM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    i have the exact same problem, the code is the speed sensor but i don't know where it is. I'm hoping its a loose wire because the new speed sensors are pretty expensive.
  5. Mar 27, 2009 at 2:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Speed sensor removal:
