Speedometer, ABS, and Emergency Brake light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlumsdenuga, Jul 31, 2014.
  1. Jul 31, 2014 at 5:37 AM
    dlumsdenuga
    dlumsdenuga [OP] New Member
    So I am new to the forum and need some help with a problem. I did the DRL OEM mod last night and everything seemed to go well and worked afterwards. This morning when I started driving to work I realized that the speedometer didn't work at all and the ABS light and Emergency Brake light stay on. I'm not sure exactly what I could have done that would have messed those up, but could use any help or advise where to look. Thanks for any help in advance.
  2. Jul 31, 2014 at 9:49 AM
    dlumsdenuga
  3. Jul 31, 2014 at 3:01 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Check Ign1 no. 2 fuse behind the cubby near your left knee when you are seated in the drivers seat (It is a 10 Amp fuse, should be in the second row down of fuses on the far left hand side of the fuse block). You likely shorted something out and blew the fuse. Does the radio and AC blower work?
  4. Aug 4, 2014 at 12:20 PM
    08TRDOFFROAD
    Dan
    Did you get your problem figured out?
  5. Aug 4, 2014 at 8:29 PM
    Nutzo333
    Nutzo333 FreakShow333
    Cory
    Canada
    Lifted 06 SR5
    6" Fabtech Lift, 315/70 r17 Duratracs, TRD Cold Air Intake MBRP stainless with duel side exit rear exhaust
    Hope its a fuse bud. For me, when the good ol ABS, CEL, and park brake light came on... was cause all four of my ABS sensors were cooked
  6. Aug 5, 2014 at 12:44 AM
    MadMatt
    MadMatt Member
    PreRunner SR5
    Switchback signals, led stop lights.
    How did all the wheel sensors get cooked? Seems a little odd...
  7. Aug 5, 2014 at 8:01 PM
    Nutzo333
    Cory
    Canada
    Lifted 06 SR5
    Lift kit did most of the work on them lol. Plus its an 06, milage racking up, sees a lot of bush time. They didnt all go at once. one by one over a few months.
