Speedometer and Odometer error corrected easily
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tinkmeister1, Aug 31, 2013.
  1. Nov 18, 2015 at 5:06 PM
    #41
    dislexiclawyer
    dislexiclawyer Well-Known Member
    Missouri
    I read through some of your math, but could not put together a formula to find the right gear for the 285/70 R17 tires I am running. When I am at 65 on my speedo, I am actually going closer to 70. I have done a speedo cable gear change on my old explorer before, but a forum I belonged to had a gear calculator that was put together by a member.
    Could you post the formula you used? Having an accurate speedo would be nice. I know I need to go down in size on the gear.
    Lt_Dan likes this.
  2. Nov 18, 2015 at 8:11 PM
    #42
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    Do you know where to buy the gears?
  3. Nov 18, 2015 at 8:25 PM
    #43
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I think all car makers ( bump up) the speedo a tad to get those mpg readings they want to see. I run 285s on stock gears and am barely off. When I had stock tires I would drive by a radar and read 5mph more than radar read. Now with the 285s I'm 1-2 mph slower than radar reading.
  4. Nov 18, 2015 at 8:55 PM
    #44
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  5. Nov 18, 2015 at 9:39 PM
    #45
    Lt_Dan
    Daniel
    Cincinnati OH
  6. Nov 18, 2015 at 10:28 PM
    #46
    bsaunder
    bsaunder Well-Known Member
    Colorado
    2015 DCSB TRD 6spd
    Or to reduce their warranty liability duration
  7. Jul 13, 2018 at 9:31 PM
    #47
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    Just found this thread. I have been interested in fixing my odometer since I re-geard to 4:56 and have 255/85/16 tires (tall 33's). I know there is an inline module by Hypertech but that is $200+ for a simple calibrator that I could probably make with an Arduino for $70.
    I may consider changing gears to just get a more accurate odometer. My odometer reads more miles due to my gear/ tire combo.
    Awesome Thread.
  8. Jul 14, 2018 at 9:21 AM
    #48
    Taco'09
    Taco'09 Well-Known Member
    Hmmm. You may be looking a long time for the gear to replace. My '14 6-speed does not use the sensor described in this thread. There is simply a blank plug where the sensor use to be. This probably started back with the '09s when Toy decided to radically increase the use of electronics.
  9. Jul 16, 2018 at 11:13 AM
    #49
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
  10. Mar 13, 2020 at 8:19 AM
    #50
    pinktaco808
    pinktaco808 Hot Steppa
    How accurate is those what your speed is going on the road?
