Speedometer and Odometer mod/DIY for 33"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoflaco, Jan 9, 2014.
  1. Jan 9, 2014 at 1:15 PM
    tacoflaco
    tacoflaco [OP] Well-Known Member
    Sean
    Bay Area, CA
    2013 ACLB Baja
    SnugTop SuperSport SpiderTrax 1.25" Spacers BAMF Sliders OEM smoked headlamps Pro Grille Paint matched grille surround Tepui RTT
    Hello all. Wondering if there is a mod or DIY we can do to correct our speedometer and odometer to accurately report speed and mileage. I did a search but couldn't come up with anything conclusive. Any help is appreciated. Thanks!
  2. Jan 9, 2014 at 1:20 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i THINK they make calibrators for the Speedo for the Tacomas.. not 100% sure. I had one for my Jeep years ago.
    the odometer.. just use the tire size calculator to figure out the percentage difference in size.
    for example.. for me.. im 6.4% percent larger than stock.. so say my trip reads 300 when the low fuel light comes on.. 300 x 1.064 = 319 actual miles.
    hope this helps
  3. Jan 9, 2014 at 1:27 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I really do not think there is a fix. Contact the dealer as they should know. The easiest way is a GPS.
  4. Jan 9, 2014 at 1:34 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    It depends. Some models pick up the speed signal from the transfer case (manual trans only I believe) and it is easy to correct by changing the plastic gear in the T-case. Others use the wheel speed sensors and require use of a "dakota digital SGI-5". I have a manual trans 05 and my speedo is correct with 37" tires and 4.88 gears, without doing anything (other than regearing).
  5. Jan 9, 2014 at 1:37 PM
    tacoflaco
    Sean
    Bay Area, CA
    2013 ACLB Baja
    Wow! Thanks for all the help everyone!
  6. Jan 9, 2014 at 1:51 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
  7. Jan 9, 2014 at 1:52 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  8. Jan 9, 2014 at 1:53 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ah HA! they do make them.. hmmm. same one I used for my Jeep back in the day too.
  9. Jan 9, 2014 at 2:39 PM
    tacoflaco
    Sean
    Bay Area, CA
    2013 ACLB Baja
    Awesome. Thanks everyone! Very much appreciated. Just put 33" tires on yesterday and want to take care of this next. Glad it is going to be so easy.
