Speedometer and odometer not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by sparky34, Dec 31, 2019.
  1. Dec 31, 2019 at 1:16 PM
    sparky34
    sparky34 [OP] Member
    2000 tacoma xtra cab
    manual hub swap aftermarket deck 882 bilsteins 1.25 daystar shackle Trans temp guage
    The speedometer as well as the odometer in my 2000 Tacoma v6 4x4 is not working
    I have replaced the speed sensor and gear, Tried a second cluster, checked all fuses,checked grounds, test speed sensor number 2 and the speedometer still wont work.
    Thinking it is a wiring issue but unsure of the pins at the cluster to check continuity. also i am unsure how the harness is routed after it disappears over top of the trans.
    has anyone else had a similar problem and found a solution?
  2. Dec 31, 2019 at 3:33 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Do you have an OBDII scanner? THe one I have (blue tooth) connects to my phone with Torque Pro and it will display speed as well. Might help figure out if speed is getting to the ECU but not back to the cluster...
  3. Dec 31, 2019 at 5:11 PM
    sparky34
    I tried the scanner and it displays the speed as zero.
    Does anyone know what connector and what pins are for the speedo in the cluster?
  4. Jan 1, 2020 at 10:34 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If the scanner reads 0 mph when the truck is moving, then it's not getting any speed input from whatever speed sensor is on the truck. I would take a look at that next first. If that looks good, then I would suspect whatever's between the sensor and the cluster head.
  5. Jan 1, 2020 at 7:51 PM
    sparky34
    pulled in new wires from the sensor and spliced into the harness at the glove box and its working again
    cruiserguy likes this.
  6. Jan 1, 2020 at 8:17 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Nice work hermano, good to hear you got it fixed:D
  7. Jan 2, 2020 at 11:04 AM
    skeezix
    Colorado
    1998 Limited
