Speedometer and odometer quit working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrianJstill, Apr 21, 2019.
  1. Apr 21, 2019 at 5:08 PM
    BrianJstill
    BrianJstill [OP] New Member
    Brian
    2008 White Taco
    6in' Tough Country Lift, SPC upper control arms, Rancho 2.5 front coil overs
    2008 Tacoma, My truck sat for a couple months of working on it, once i was done i tried starting it and got the dead battery and relays clicking sound. After i put the battery on a tender overnight, the truck started and ran fine except the speedometer and odometer quick working. My radio also quit. I have checked wiring and fuses, and i am thinking the under voltage took out something. Check engine light is on, and i plan on getting the code read this week. Looking at many forums, i have seen people leading towards changing the gauge cluster, and other change the speed sensors on the transmission. I was just curious if anyone else came across this situation after a dead battery. End result is i i will be replacing something lol
  2. Apr 21, 2019 at 9:23 PM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    So what kind of work did you do to the truck the last couple months? If the gauges were working properly before it’s likely something you may have done. How do the battery terminals look?
  3. Apr 22, 2019 at 6:51 AM
    BrianJstill
    Brian
    2008 White Taco
    Battery terminals are fine, no fuzz or corrosion, I have removed the gas tank and truck bed to repair broken rear brake lines. That turned into restoring the entire rear end of the truck with KBS coatings, and new stainless steal brake lines, and struts. I also installed new rocker panels. I made sure to disconnect the battery during any welding activity. My ABS has never worked right, so I disconnected the rear two sensors to clean up the look.
  4. Apr 22, 2019 at 10:26 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That could be a (the) problem. :eek:
    Skyway and 1E7DCSB like this.
  5. Apr 22, 2019 at 12:18 PM
    Muddinfun
    Muddinfun Well-Known Member
    ^yeah, what he said.
    A TW member posted somewhere that the speedometer gets it's reading from the right rear wheel sensor. Don't know if that's true, but if so, that would explain your situation.
  6. Apr 22, 2019 at 4:20 PM
    BrianJstill
    Brian
    2008 White Taco
    I'll try hooking up the rear ABS harness and see if that works again, to me it seems to operate a whole different system, but computers do strange things when collecting data and from where
    Skyway likes this.
  7. Apr 22, 2019 at 5:55 PM
    DirtTaco
    DirtTaco Well-Known Member
    I ripped out the wire to the sensor going through a creek crossing and it cut the Speedo and odometer. That’s your problem- plug them back in.
    icygator likes this.
  8. Apr 22, 2019 at 7:11 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    There you go O.P..
  9. May 7, 2019 at 6:06 PM
    Red All Around
    Red All Around Active Member
    Brandon
    Utah
    05 DCLB 4WD
    Leer 100XR Topper shell, WeatherTechs, Heavy duty rear leaves, Bilstein 5100 rear shocks, Bushwacker fenders.
    Not to kick up a dead thread, but one issue I've noticed on my 05 DCLB is very rarely, maybe once a year, my speedometer simply quits working, just the speedo and nothing else. I've noticed this in the extreme cold (minus zero), warm temps (95+) or simply average weather. I go through the normal checks, looking at any other gauge cluster not working, and checking the fuses for anything blown, and I always turn up empty handed. Luckily enough *knocking on wood* the issue remedies itself after letting it sit for a few hours.
    Just shooting this out there to see if anyone has ever experienced this issue and knows what the potential culprit might be.
