Speedometer bouncing
Discussion in '1st Gen. Tacomas (1995-2004)' started by buzzboy, Jul 28, 2010.
  1. Jul 28, 2010 at 11:23 PM
    buzzboy
    buzzboy [OP] Member
    san diego
    2001 Creampuff
    2 into 1 lighter adapter!
    I have a 95 tacoma with a malfunctioning speedometer. At highway speed it bounces back and forth. For example, if I'm at 65 mph the speedo twitches quickly between 60 and 75 mph.
    In a possibly related issue, the cruise contol bucks/lurches whiile on the freeway. Thinking the speedo problem is causing the c/c problem? Sometimes the c/c even turns off. Heard the speedo fix is a little expensive due to the labor involved? I couldn't find any closely related threads in the search, does anyone have any info on repair costs and if the 2 issues may be related?
  2. Jul 28, 2010 at 11:39 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    could be a speed sensor or your speedometer going bad for the speedometer. For the c/c issue, maybe the c/c module
  3. Jul 29, 2010 at 8:12 AM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    On a 95 the speed sensor is mechanical. unlike the newer ones.It may be an easy fix.
  4. Jul 29, 2010 at 5:32 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Sounds like you need a speedo cable, to me. Should be real easy to replace.
    Pull out the cluster, and unscrew the cable.
    Unscrew cable from trans.
    Unbolt the cable from the various brackets.
    Route old cable out of cab.
    Install in reverse order.
  5. Jul 30, 2010 at 8:29 AM
    98tacoma27
    Ben
    Not Beech Creek
