Speedometer Calibration Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AFTaco, Jul 25, 2009.
  1. Jul 25, 2009 at 2:28 PM
    AFTaco
    AFTaco [OP] Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    This might be another newbie question, I looked and didnt find anything on the search. Can the speedometer/odometer be recalibrated with bigger tires?
  2. Jul 25, 2009 at 2:48 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Yes, at least it worked for me.
    My speedo was about 3 mph over my actual speed. Going from a 265/65R17 tire to a 265/70R17 put my speedo right on my actual speed.
  3. Jul 25, 2009 at 3:14 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    no. only way to fix speedo and such is to regear. 4.10s w/ 33 should put you back to oem.(if you have 245s originally)
    Rocketball - ?. you actually didnt recalibrate your speedo, just the original error in your speedo was corrected.
  4. Jul 25, 2009 at 3:28 PM
    AFTaco
    Doug
    Anchorage, Alaska
    TRD Off-road
    What do you mean by regear. Could you translate 4.10s, what does that mean? Sorry, i'm kinda new to the forum thing. Thanks
  5. Jul 25, 2009 at 3:40 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    no worries. regear means to change the gears in your rear axle to a different ratio. you currently have a 3.73 ratio, meaning it takes 3.73 turns of the driveshaft to equal one full rotation of your rear axle. if you regear to a 3.91 ratio with 33" tires, you will get back to nearly the same speed reading as you did with your original setup.
    now, regearing is expensive. your best bet would be to find a complete third member from a previous gen tacoma (95-04) and drop that in. if you dont want that, you will have to purchase a 3.91 gear set and have them installed. installation can run anywhere from $300 to $1000 for a single axle and im sure gears are over $200 (havent priced them, but this is my guess).
    make sense?
  6. Jul 25, 2009 at 3:42 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    which is not necessary for 33's on a v6 and it will most likely put ur speedo closer to actual than b4
  7. Jul 25, 2009 at 3:50 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ your right actually (edited my original post), im thinking of my situation, where my truck came stock with 245s.
  8. Jul 25, 2009 at 11:59 PM
    AFTaco
    Doug
    Anchorage, Alaska
    TRD Off-road
    Thanks for the info. Sounds like a PITA. Is there a computer that can tell u ur actual speed with the biger tires?
  9. Jul 26, 2009 at 12:01 AM
    AFTaco
    Doug
    Anchorage, Alaska
    TRD Off-road
    So ur telling me that if I put on 33's, my speed will be more acurate than my stock tires? 33's is what I was planning on going with anyways. Hope this is true.
  10. Jul 26, 2009 at 1:16 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    not really a pain. if you have the money or mechanic knowledge its not bad at all.
    there are no computers that will correct this to my knowledge. is a calculator that you can play with different tire sizes and it will tell you all the dimensions and % difference.
    EDIT: and after playing around with it, i take back what i posted earlier...33s and stock gears will have your speedo read slightly slow, but you should be ok.
  11. Jul 26, 2009 at 2:50 AM
    Illuminaut
    Illuminaut life's a conspiracy
    (Z)ion)o)sphere
    2009 Regular Cab 4x4 in BSP
    .75" Front Aluminum Billet Spacers = 1.5" Lift ((silly mud flaps removed pending trimming)) AFE Pro Dry S with secondary filter removed 265/70/16 Goodyear Wrangler Silent Armors mounted on Limited Edition Toyota Black Bajas
    In the 2nd Gen 4x4 up to +5% on the speedometer/odometer is normal, stock from the factory.
    Going up from the stock 31" to 32" tires usually corrects the discrepency just about perfectly... :D
  12. Jul 26, 2009 at 6:37 AM
    Rocketball
    Scott
    Westminster, MD
    The end result is the same.
  13. Jul 26, 2009 at 6:51 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    with my 285/70/17s (perfect 33" OD) my speedo is 3-4 MPH slow. Thats quite a bit off. The odometer is usually about 30 miles off at a fill up too.
  14. Jul 26, 2009 at 6:53 AM
    Burgman
    Stephen
    Ric VA
    brian thats what mine is off at 65, so iguess it just flips which way its off
  15. Sep 30, 2009 at 6:53 AM
    Jwortley
    Jwortley New Member
    2009 tacoma pre-runner
    Running boards Bull bar
    hypertechs inline speedometer calibrator module will make the adjustment. All you do is program in the new tire size and connect it to the speedometer to fix any discrepencies created by the tire size or the rear gear ratios
  16. Sep 24, 2014 at 8:57 AM
    PackMatt
    PackMatt PackMule
    James
    Norco,CA
    4x4 reg cab taco
    ARB OME 3in lift, 33's on FJ rims, ARB air lockers, 4.88 gears, snugtop shell.
    I put 285/70 r17 on my 2014 4x4 and I was told regearing from my stck 4.10s to 4.56s would put the speeddo correct, but I went with 4.88s and it runs so much better than before. I have a 4 cylinder.
  17. Sep 24, 2014 at 9:02 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    This. Love mine.
  18. Sep 24, 2014 at 9:13 AM
    tacoflaco
    tacoflaco Well-Known Member
    Sean
    Bay Area, CA
    2013 ACLB Baja
    SnugTop SuperSport SpiderTrax 1.25" Spacers BAMF Sliders OEM smoked headlamps Pro Grille Paint matched grille surround Tepui RTT
    Hypertech makes a plug and play device to reprogram/recalibrate the speedo. Easy to use and inexpensive as well.
  19. Jun 30, 2019 at 5:26 PM
    cwallachy
    cwallachy Well-Known Member
    SETX
    2015 Tacoma TRD Sport
    Window Tint, ICI Magnum RT Step Bars, Ballistic Canvas seat covers with Molle backs, RCI Bed Rack with CVT RTT, CBI ditch light brackets with Floods, Rear Channel Bed Stiffeners from Off Road Warehouse
    Just wondering how useful the Hypertech Speedometer Calibrating tool is. Was going to go from P265/65/R17 stock tires to Falken A/T P275/75/R17's and would like to have the speedometer and odometer be corrected WITHOUT having to regear... is it worth the tool cost?
  20. Jun 30, 2019 at 6:00 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It is literally impossible to get the speedometer, or odometer for that matter to be 100% accurate. About 5% error is as good as can be expected. That means you're off by about 3-4 mph at 75. This isn't anything new, all cars since they've been invented do this. We just didn't know until everyone got a GPS.
    As tires wear down the diameter changes to roughly 1 size smaller tire. If it is calibrated 100% accurate when you're tires are new it will be off by about 5% as they are near the end of their useful life. If they are off when new, they will either be accurate when worn, or off even more.
    Unless you change to a significantly larger tire I wouldn't worry about it. If your speedometer is within 5 mph at 75 mph you're chasing unicorns to get it calibrated. If you were to go from a factory 31" tire to 35" or 37" tires then it might matter. Not worth the trouble for 32" or 33" tires.
    Do you mean 275/70/17. I don't think they make a 275/75/17. My truck with stock tires was 2 mph slower than my GPS. When I went up size larger the speedometer and odometer were right on the money. But as the tires wore the speedometer started showing me 2 mph slower than the GPS.
    cwallachy likes this.
