Speedometer Calibration
Discussion in 'Wheels & Tires' started by Canyon lands, Sep 19, 2020.
  1. Sep 19, 2020 at 1:25 PM
    Canyon lands
    Canyon lands [OP] Well-Known Member
    Bill
    Colorado
    2015 red Tacoma TRD off-road
    3” lift, leer topper, James Baroud tent, Lund bull bar, 4 wheel running boards, Pioneer stereo, fosgate speakers, amp, bed slide, Thule racks, road shower
    I just recently purchased a 2015 Tacoma with a Toytec / Old Man Emu 3” lift. 285/85/17 tires. From checking the vin # with Toyota and it looks like the Tacoma came with P245/75R/16’s. The tire calculator shows that the speedo is waaaaay off. Does Toyota do speedometer calibrations ?:fingerscrossed:
  2. Sep 19, 2020 at 3:30 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I don’t believe there is a way for the dealer to do it. Also do you mean a 285/70/17 the tire size you put down is 36” and no way that would fit with a 3” kit. I run 285s and my Speedo is dead on as they are usually off from the factory.
  3. Sep 19, 2020 at 7:00 PM
    Canyon lands
    Bill
    Colorado
    Yep, you’re right‍♂️ Fat fingered that one! LT285/70R/17. I’ve tested it against two other vehicles and seems to be quite a ways off at 65, just wanted to make sure it was close.
  4. Sep 19, 2020 at 7:04 PM
    gotoman1969
    a simple quick check is to use the mile markers on the highway. Go 60 and it should take 1 minute between markers. Then you’ll have a very good idea.
  5. Sep 19, 2020 at 7:06 PM
    Canyon lands
    Bill
    Colorado
    That makes too much sense! Have no idea why I didn’t even think of that. Thanks
  6. Sep 19, 2020 at 7:06 PM
    gotoman1969
    I have a Highway patrol officer that lives in my neighborhood. So I had him radar me. So that’s how I know mine is dead on.
  7. Sep 19, 2020 at 7:07 PM
    gotoman1969
    Sometimes it’s the simple ideas we forget about.
  8. Sep 19, 2020 at 7:08 PM
    Canyon lands
    Bill
    Colorado
    That could be handy. And a great way to check it.
  9. Sep 19, 2020 at 7:14 PM
    Canyon lands
    Bill
    Colorado
    So is there no way to recalibrate a Gen 2 Tacoma if it is off? Too used to tuners on diesels, enter the distance of one tire revolution, and recalibrated!
  10. Sep 19, 2020 at 7:18 PM
    gotoman1969
    I believe there are some aftermarket ones that you plug into the OBD2 port. But I’m not sure if you can actually change the setting in the factory computer to permanently correct it. I’d do the hwy check. You might find out its not as far off as you think it might be. A lot of the speedos are fast from the factory so when you go bigger tires they end being pretty close to being right on.
  11. Sep 19, 2020 at 7:28 PM
    Canyon lands
    Bill
    Colorado
    That will be the first step for sure. Once upon a time, a guy could just change the gear on the speedometer cable in the tranny. Giving away my age now I assumed that if anything was off, that someone had a means of recalibration gore changing shift points, etc.
  12. Sep 19, 2020 at 7:33 PM
    gotoman1969
    Yep. I remember those day. Just switch the little gear at the tranny housing. Fixed!! On our 2015 they use the right rear wheel sensor for the speedo.
  13. Sep 19, 2020 at 7:45 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Check with a GPS. Chances are that you MIGHT be 5 mph off at 70 mph. At slower speeds not enough to worry about. Most Tacoma's are off from the factory and adding bigger tires often corrects the speedometer. Mine said 70 mph and GPS said 68 with factory tires. Going up to 265/75/16's resulted in both reading the same.
    Plug in numbers here Remember tires don't stay the same size. As you drive they wear down and get smaller so you're never going to get the speedometer exactly right all the time. By the time you wear out a set of tires they will be an inch or more smaller. Roughly the same as going down one tire size.
  14. Sep 19, 2020 at 8:19 PM
    Canyon lands
    Bill
    Colorado
    Using the gps may be another easy way to verify. Hard to believe the speedometer on the Tacoma is that far off. Using the link you posted, the difference is significant, or at least enough for a ticket in Colorado!
  15. Sep 19, 2020 at 8:26 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    Until you do get it recalibrated, use this to figure out your speed on dash vs actual. Looks like it's a 4 mph difference depending on speed. The faster you go the more it's off.
  16. Sep 19, 2020 at 8:32 PM
    Canyon lands
    Bill
    Colorado
    Do you have any suggestions for recalibration? I’ve seen a couple aftermarket mentions on threads, but, nothing that sounds great.
  17. Sep 19, 2020 at 8:48 PM
    Canyon lands
    Bill
    Colorado
    Original Tire Size, New tire size,
    245/ 75R 16. 285/75R 17
    Speedometer Reading 65, actual speed would be 72.17. Any change in shift points at that difference, or under load. Lots of questions keep coming up, as I think about it :help:
  18. Sep 19, 2020 at 8:58 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
  19. Sep 19, 2020 at 9:00 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  20. Sep 19, 2020 at 10:39 PM
    Foster1
    California
    2023 SR V6 4x4
    You might have done it wrong there lol. 285/75r17 is a 34 inch tire. You're going with 285/70r17 (33") right?
    Just hop on the highway with google maps running, it will tell you your speed via gps and then compare it to your dash. It shouldn't be off by much. Sorry I dont have any advice on what to use to calibrate, I've never done it before.
    Do the google maps thing though, get up to 65 on the dash and compare it to what google is saying your speed is.
