Speedometer calibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bigbalzer70, Nov 16, 2021.
  1. Feb 9, 2022 at 8:52 AM
    Lambo9418
    Lambo9418 Well-Known Member
    JP
    Black 2019 TRD Pro
    Interesting... any numbers you can put to this to quantify it? I have 35K miles on my stock 265/70R16s and am strongly leaning towards moving up to 265/75R16s myself when the time comes later this year. Up until I read your post, I've been thinking that both the speedometer and odometer will need to be recalibrated...
  2. Feb 9, 2022 at 8:57 AM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    I'm on my 3rd Tacoma (a 1st, 2nd and 3rd gen), and the speedometers read 2-3mph high by a couple MPH on all of them from the factory. Slightly upping tire size usually puts them dead on. Use your GPS on your phone while driving to verify true speed.
  3. Feb 9, 2022 at 9:13 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    As it has been mentioned. When I went to 265/75/16 the speedo reading became more accurate based on radar and GPS.
  4. Feb 9, 2022 at 9:26 AM
    kev42
    kev42 Well-Known Member
    North GA
    2022 Army Green TRD Sport 4x4
    I'll be lifting my 2022 soon and putting on 275s or 285s. Looks like hypertech or RC don't support 22 Tacos yet. Has anyone tried on one yet?
  5. Feb 9, 2022 at 9:27 AM
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    I went to 265/75/16 and mine is off by 2MPH. If I do 55 indicated in the truck, I'm actually doing 57MPH. Confirmed by a cop friend of mine I asked to radar me driving down the road- as every one of these speed radar boxes they have on the sides of some roads were all showing 2mph off. He calibrated his radar unit at the start of his shift, he clocked me an hour after that. 37mph clocked when I was doing 35mph on the truck speedometer.
    2mph isn't enough of a concern for me to justify spending $170+
  6. Feb 9, 2022 at 10:58 AM
    Lambo9418
    JP
    Black 2019 TRD Pro
    Interesting... and how about your odometer?
  7. Feb 9, 2022 at 1:42 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    In my experience everything gets corrected including mileage odometer readings and speed. I have checked this with my gas buddy app and the mileage calculations manually and on my display are really close overall. Gas buddy calc showed 17.5 mpg and truck readout showed same. I recently ran my truck well into the empty range on a trip in fact I went 2 miles past the point where the gas fill up light came on, and I had space for 1.6 gallons based on manual calculations. I’d say that’s close enough. I checked the speedo setting while on cruise control with my GPS app on my phone and they matched over about a 5 mile stretch. I don’t know anything about the transmission shifting. I guess I haven’t noticed it seems to shift OK. Not sure I would notice if it did not.
  8. Feb 9, 2022 at 1:47 PM
    758_Moto
    Awesome, appreciate the feedback.
  9. Feb 9, 2022 at 1:49 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Not yet mentioned in this thread is the possible difference between a corrected speedometer/odometer and the Cruise Control speed display. From other threads on this topic, I understood these devices (Hypertech or RC) do not correct the Cruise Control displayed speed. What are you guys finding?
    I know there was a post above that said the dealer could not adjust the speedometer for a reason; I have found dealers to not be as honorable as they could be in stating the true reasons for their inabilities, so that makes me ask the question "Could Tech Stream take care of tire size changes?" After all there are differences in stock tire sizes, that I am assuming the factory adjusts for accordingly, that adjustment I assume would be with Tech Stream. As of yet I have no experience with Tech Stream, just putting this out there for consideration.
    Another item I see in this thread is some posters are using gear ratio changes as a reason for either the Hypertech or RC. My understanding so far is the speedometer display on the dash is derived by the four speed sensors on our hubs and not within the transmission or transfer case. This would make it so only a tire size change would affect the speedometer display. Please correct my understanding if incorrect.
  10. Feb 9, 2022 at 1:52 PM
    758_Moto
    From what I've read, the cruise control speed will be off and there is no way to fix it.
    The speed sensors are in the wheels so you do not need to change the gearing for the Hypertech/RC calibrator. Only change the tire size.
    Toycoma2021 likes this.
  11. Feb 9, 2022 at 2:47 PM
    Ronk44
    Rockerville, SD
    2017 MGM Sport
    My electronic digital speed seems right on with cruise control set. This is how I checked it! Had my phone with GPS app running right next to it.
  12. Mar 11, 2022 at 6:35 PM
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    Anyone with 255/85r16's notice if their reading are actually closer to true?
  13. Mar 11, 2022 at 7:09 PM
    Toycoma2021
    My stock 2021 OR was right on from the factory. Haven't ever had a speedometer so accurate. Compared with two GPS units. However, when I changed to 255/85/16 my displayed speed is lower than the real speed. Displayed 61MPH, real 65MPH.
  14. Jul 31, 2022 at 8:09 AM
    Fred_e81
    Fred_e81 Well-Known Member
    Fred
    2018 Cement TRD Offroad
    I am looking at getting my speedometer recalibrated using one of the aforementioned units. Does it matter if I have 4wd or rear wheel drive? When I select the rear wheel drive for my truck on the websites it says not compatible. Anyone w non 4wd install this on their truck? Any help would be appreciated. Thanks
  15. Aug 10, 2022 at 7:46 PM
    #35
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    Installed on a 19 tonight. Cannot get it to work. Wondering if windows 11 is the prob? Says successfully programed (30.6” to 32.8”) I go plug it in n nodda. Tried 6 times. Frustrated atm. Only thing I can think of is it’s windows 11? Website mentions up to windows 11
  16. Aug 10, 2022 at 8:20 PM
    #36
    Fred_e81
    Fred
    It could very well be. I tried it on an older laptop and I could not get the drivers to install. My son did it on his MacBook and it worked perfect.
    hope you get it figured out soon.
    mAtTyG04[QUOTED] likes this.
  17. Jan 7, 2025 at 11:01 PM
    #37
    jkish17
    jkish17 Well-Known Member
    Roseville, CA
    2018 DCLB TRD OR
    -Dobinson’s IMS shocks on C59-354 coils -Dobinson’s rear shocks -Dobinson’s L59-111-R heavy leafs -Wheeler’ off road super bumpstops -Wheeler’s off road U-bolt flip -JBA Upper control arms. -35x12.5r17 Yoko Geo MT’s -17x7.5 4Runner spare steel wheels (Part #42611-35430) -Trailgear 1.5 spacers -C4 fabrication rock sliders -Relentless Fabrication High Clearance Rear Bumper, no swingout. -CBI T3 front plate bumper, no hoop/bullbar. -Ironman 4x4 12,000lb synthetic winch -Victory 4x4 roof rack -China camper from Alibaba -CVC tuned -ExtremeLED lightbars in the roof rack and front bumper. -Baja Squadron's in the rear bumper -MESO customs stuff everywhere -Dobinson’s Zenith air compressor mounted under the hood -Homemade S-pod relay box -Entire sound system replaced and sound deadening added
    This might be a stupid question but will this work if your truck is tuned?
  18. Jan 7, 2025 at 11:10 PM
    #38
    Toycoma2021
    The only stupid question is the one unasked. Yes, the calibrators work despite a tune.
    The wheel sensors are the only place speed is sensed on these 3rd gens.
