Speedometer correction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KevC, Jun 11, 2017.
  1. Aug 4, 2018 at 4:12 PM
    #41
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Because with the stock size tires from the factory has always over reported speed/mileage (never was accurate from the factory until you put a inch taller tire on).. This isn't only a Toyota thing, all manufactures do this, I'm assuming they do it to get past the bullshit EPA gas mileage regulations
  2. Aug 4, 2018 at 5:20 PM
    #42
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The speedo and odometer have separate calibrations in the gauge cluster. Over-reporting is done intentionally for the speedo but not for the odometer.
    NMTrailRider likes this.
  3. Aug 4, 2018 at 10:18 PM
    #43
    KenLyns
    Belly of the Beast
    Correct. Note both measurements are subject to mfg tolerances, but the median value for the speedo is shifted by about 3 mph.
    Common with most vehicles: https://www.caranddriver.com/news/w...iving-accurate-mpg-readings-and-how-to-fix-it
    Most of the error in the in-vehicle MPG display comes from the fuel system. Since there's no flow meter in the system, fuel consumption is estimated indirectly based on injector pulse timing. The fuel injected in each combustion cycle, on the order of microliters, will have huge variation when multiplied thousands of times each minute.
    plamore likes this.
  4. Aug 4, 2018 at 11:19 PM
    #44
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Dude... You're killing' me at 1:19am with that sig.
    KenLyns[QUOTED] likes this.
  5. Aug 5, 2018 at 12:10 AM
    #45
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    In summary...
    Just to be clear-- we assume the speedometer and odometer are operating via the same mechanism. They're both dependent on RPM of the wheels.
    It's been established that our trucks come from the factory with the speedometers reading 2-3mph faster than "reality" at hiway speeds (ie. when your speedometer says 67mph, you're actually going 65mph). Who knows why they do this. It's not relevant to the conversation. When you're driving at 5mph, the speedometer will be spot on (imperceptible error). The "error" gets larger the faster you go.
    That said, its likely (and evident, as per forum posts) that even though the speedometer is under-reporting from
    the factory, the odometer is accurate.
    So. If you put a bigger than OEM tire on (~1" larger in diameter) there are fewer RPM. This has the effect of "correcting" our speedometers. Your speedometer is now displaying "reality". But your odometer is now under-reporting by a small percentage (ex. ~3000 miles per 100,000 miles).
    Speculation here, but I'm guessing that the onboard mpg calculations are based off the odometer and not the speedometer (it just makes sense). So, mpg calculations will be ~correct with OEM tire size, even though the speedometer is off by 2-3mph at hiway speeds. If you install larger tires, your displayed mpg will not be accurate. It will likely show worse mpg that what you're actually getting.
    mlr69 likes this.
  6. Aug 5, 2018 at 12:42 PM
    #46
    KenLyns
    Belly of the Beast
    Unfortunately she's married :(
  7. Sep 3, 2018 at 1:55 PM
    #47
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Subbed
  8. Sep 3, 2018 at 2:46 PM
    #48
    urmaker45
    urmaker45 Well-Known Member
    Brad
    Wise, va
    2017 tacoma trd offroad
    I have noticed my speedo is about 2 to 3 off of my digital speedo .
  9. Sep 3, 2018 at 4:03 PM
    #49
    NMTrailRider
    New Mexico
    Same here.
  10. Sep 3, 2018 at 4:09 PM
    #50
    RushT
    North Texas
    Happy for him then!
  11. Sep 3, 2018 at 4:10 PM
    #51
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My GPS shows 64 when the cruise is set at 65. Hopefully my new 265/70/17 bfgs will make it spot on.
  12. Sep 18, 2018 at 4:33 PM
    #52
    Espoitis
    Espoitis Active Member
    Corpus Christi, Texas 78413
    2013 Tacoma DCSB TRD OR 4x4, Grey
    Looks like a 3 inch lift, P285 70 R17, BFG A/T KO2
    I’m using 285 70 17... my speedo is slower by 4 mph. It’s crucial to know this and correct it especially when you get pulled over and you’re arguing with the police officer that in fact you were going the speed limit when in actuality you were not. 75 mph on speedo is actually 79.... any fix?
  13. Sep 18, 2018 at 4:37 PM
    #53
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    See post #27.
  14. Sep 18, 2018 at 4:49 PM
    #54
    Espoitis
    Thank you! 229.00 though?! Wow is there a cheaper way to fix this? I don’t have original rims to put them back. Truck was like this when I bought it.
  15. Sep 18, 2018 at 4:51 PM
    #55
    mlr69
    South Carolina
    It was worth it for me, I could not stand the speedometer and odometer being off. I'm not aware of any other device that'll fix it.
    RogueTacoma likes this.
  16. May 3, 2020 at 3:28 PM
    #56
    lpfe42
    lpfe42 Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    How did it work out?
  17. May 3, 2020 at 3:38 PM
    #57
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    I purchased and didn’t look back, with it
    agree
    lpfe42 likes this.
  18. May 3, 2020 at 3:40 PM
    #58
    lpfe42
    Kenny
    20 DCSB CEMENT
    5100/887 Icon uca
    ill call Hypertech in the am to see if its the same for the 2020
    LostHusker[QUOTED] likes this.
  19. May 3, 2020 at 4:13 PM
    #59
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Don't waste your time. The Hypertech in-line module currently doesn't support the 2019 or the 2020, and they have no idea when or if they'll ever update it for the Tacoma. I've asked them several times since November of last year, and always get the same answer.
    lpfe42[QUOTED] likes this.
  20. May 3, 2020 at 4:21 PM
    #60
    BravoSix
    BravoSix Well-Known Member
    2017 MGM SR5 DCSB 4x4
    Seat jackers, Tonneau, Toyo AT3 235 85 16.
    What about 235 85 16?
