Speedometer for 05
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpktaco, Sep 9, 2023.
  1. Sep 9, 2023 at 12:22 PM
    rpktaco
    rpktaco [OP] Well-Known Member
    nj
    05 sr5 trd
    Does anyone know what speedometers will fit my Tacoma the part # I have had been discontinued by Toyota so will 06 to 11 fit ? When I look up the part # doesn’t show a alternative part #
  2. Sep 9, 2023 at 10:07 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    05-11 should work. Don’t forget your mileage is directly built in to the cluster so you will assume the mileage of the replacement
  3. Sep 10, 2023 at 4:13 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Did your needle get stuck?
    Mine stopped working before, I took the whole cluster out of the dash and sprayed the dust out with a can of electronics cleaner.
    It works fine now.
  4. Sep 11, 2023 at 12:33 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Illegal in most states too change the speedometer unless done by the dealership so as the mileage can be reset too your trucks actual mileage .
  5. Sep 11, 2023 at 1:27 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not illegal per se, it just has to be marked on the title as not actual milage should the vehicle ever be sold.
    There are companies out there that repair instrument clusters, you could also look into that.
  6. Sep 16, 2023 at 5:18 AM
    rpktaco
    nj
    05 sr5 trd
    i have a P0500 code when i was at the dealer tech said it the speedometer so i was looking to buy one from tanin auto a05 599.00 and a06 is 399.00 i emailed them and they said its based on the part numbers so i guess they dont cross reference part numbers thanks
  7. Sep 16, 2023 at 5:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    That's a speed sensor code.
    Don't think a speedo is the fix.
  8. Sep 16, 2023 at 6:04 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
