Speedometer Gear Oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by Washout, Sep 30, 2017.
  1. Sep 30, 2017 at 10:43 AM
    Washout
    Washout [OP] Active Member
    2002 Silver Tacoma TRD SR5
    TRD supercharger, 3" lift, 33" tires, front air locking diff, onboard air compressor, front steel bumper
    Hey I had to take off the speedometer to access a bolt on my transfer case, oil of course leaked out. Does anyone know what type of oil and how much should go in there?
    Thanks in advance
  2. Sep 30, 2017 at 11:18 AM
    NM Lance
    NM Lance Well-Known Member
  3. Sep 30, 2017 at 11:20 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If it wasn't a ton don't worry, the case only gets filled to the top of the fill hole and anything that high was just hanging on to the input shaft and the case molding up there.
    Chipskip likes this.
  4. Sep 30, 2017 at 12:11 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    In case it isn't clear - the speedometer gets its oil from the t-case, it doesn't have its own.
