Speedometer inconsistency
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mystert, Aug 21, 2017.
  1. Feb 2, 2018 at 12:34 PM
    mystert
    mystert [OP] Well-Known Member
    Eric
    Ventura CA
    2005 Tacoma TRD Sport 4x4 6spd
    A faulty speed sensor would give a check engine light correct? I scanned the truck the other day at the parts store just to see if I had any codes and there were none. Maybe time to invest in a copy of the Toyota Dealer software, there has to be a hack copy online somewhere.
    EDIT- I just ordered up one of those ELM wifi adapters, Ill check the speed sensor output on Sunday when I get it.
  2. Feb 2, 2018 at 6:32 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    When my speed sensor went out, my check engine light came on. I scanned it but I’ve forgotten what code it showed. My nylon speedo gear had flat spots on it & a bit chewed up so I had to get that from the dealer. Replacing both fixed mine.
  3. Feb 2, 2018 at 7:02 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Same problem for me, after a lot trying and “fixing it” I just bough a used one from a 2007.
  4. Feb 3, 2018 at 2:44 AM
    mystert
    Eric
    Ventura CA
    Used gauge cluster or speed sensor?
  5. Feb 3, 2018 at 2:56 PM
    libagui
    Dominican Republic
    05 tacoma prerunner
    Speed gauge
  6. Feb 8, 2018 at 5:35 PM
    mystert
    Eric
    Ventura CA
    Well after a week of driving with a obd2 scan gauge hooked up, I found that the speedo has read 5mph high and low at times. Finally today the speedo stuck at 10mph at a stop and the OBD2 readout was 0mph. I’m gonna call it a faulty cluster. Now to find one....ugh
  7. Feb 9, 2018 at 5:11 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    My cluster functions normally, but I do find that compared to my OBDII (Torque) that the speedometer can be off a bit at certain speeds.
