Speedometer incorrect lawsuit
Discussion in 'Wheels & Tires' started by rockbug63, Jun 8, 2011.
  1. Jun 8, 2011 at 6:48 PM
    rockbug63
    rockbug63 [OP] Active Member
    central coast CA
    '09 Dbl cab 4x4 SR5 tow pkg.
    Rear leaf and steering column chatter tsb blower mtr replaced(waste of time) 2nd blw. mtr.; new headlights from DRL melt issue new water pump9 leaking0around block) pwr steering rack leaks, right frt. wheel bearing bad.
    I just put on my first set of replacement tires on my 17" Sport rims since new. Had 265/65/17 Bridgestones. Garmin readout always showed that the speedo was indicating about 2/3 mph too fast. Put on Michln. LTX MS/2 265/70/17 and the speedo is now spot on. On my '05 Accord it did the same thing, indicated too high. Another Accord owner took Honda to court and made them extend the warranty from 100K to 105K. I got a letter stating why and fleet wide Honda was proved to have done this to increase overall gas mileage figures. I wonder if we are being duped by Toyota the same way??If your truck with factory supplied wheels and tires does this(?) then I'd say we have a case!
  2. Jun 8, 2011 at 6:53 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Lol. Not worth it to me.
  3. Jun 8, 2011 at 6:56 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  4. Jun 8, 2011 at 6:56 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I would like to know how the speedo and odo can read different from each other when the source of info is a rotating tire or tranny part. How does the speedo slow down with taller tires but the odo remain unchanged, if true?
  5. Jun 8, 2011 at 6:57 PM
    cc350
    cc350 Retired Member
    My speedo is also about 3 mph off, was told by many here that the speedo is indeed off by 2-3mph,but the odo was correct. Well after many many long trips and checking with mile markers and gps I can say for sure the odo in my truck is also off by 2.5-3 miles. Have checked it many times to be sure.
  6. Jun 8, 2011 at 7:01 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    That's not what he is saying he is saying with the factory tires the speedometer reads fast buts the odometer is spot on so a taller tire will make the speed correct but the odometer slightly off
  7. Jun 8, 2011 at 7:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sue !
    Americans are lawsuit happy :)
  8. Jun 8, 2011 at 7:10 PM
    rockbug63
    central coast CA
    Speedo and Odo both offset according to 2 different GPS units with trip mileage function and speed readouts. Just something to consider besides your next witticism.
    P.S. The new tires are perfect, glad I went Michelin.
  9. Jun 8, 2011 at 7:11 PM
    DrewH
    DrewH Well-Known Member
    I'd say get a life!
  10. Jun 8, 2011 at 7:14 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    X2, don't sweat the small things
  11. Jun 20, 2011 at 7:19 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    Ditto.
  12. Jun 20, 2011 at 7:21 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    ^^^ x2654968
  13. Jun 26, 2011 at 1:24 PM
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    Looking at new tires so maybe that'll fix the speedo issue. Are the tires sized as labelled on the sidewall ? Speedometer is off by 3 mph at 30 mph. 5mph at 65mph and 12 mph at 140mph. ;) The ODO looked corrected but I didn't check with a long distance trip.
    Stock 245/75R-16 on the taco now. Going to go with the same size so nothing should change right? I'll still just drive like my hair is on fire.
    :D
  14. Jun 26, 2011 at 7:29 PM
    David K
    I know that's what he is saying and that doesn't change my question in the least:
    "I would like to know how the speedo and odo can read different from each other when the source of info is a rotating tire or tranny part. How does the speedo slow down with taller tires but the odo remain unchanged, if true?"
  15. Jun 26, 2011 at 7:36 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Toyota would have had to program it that way. You are absolutely right, when the tire size changed, both the speedo and odo should change by the same amount.
  16. Jun 27, 2011 at 8:00 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    i know my truck goes 3mph slower than the speedo with the stock 215/70/15 on my truck.
  17. Jun 27, 2011 at 8:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Wow, seriously?
  18. Jun 27, 2011 at 8:06 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    I don't like your tone.
    I'm forwarding the blogs to my lawyer to see what kind of a case we may have.
  19. Jun 27, 2011 at 8:12 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    People actually care about this stuff? :confused:
  20. Jun 27, 2011 at 8:15 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Who gives a shit
